ASC metal can polypro caps: ground the metal can to AC ground? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th September 2006, 04:13 AM   #1
jarthel is offline jarthel  Australia
Default ASC metal can polypro caps: ground the metal can to AC ground?
your thoughts?
thanks for the help
Old 5th September 2006, 04:55 AM   #2
dsavitsk's Avatar
Yes, if they are outside the chassis where they can be touched.
Old 5th September 2006, 06:13 AM   #3
but not all metal that can be touch are grounded. say a metal knob for a volume control?
Old 5th September 2006, 09:04 AM   #4
CLS is offline CLS  Taiwan
I don't know ASC metal can, but I'd been shocked by some unshielded aluminum tops of electrolyte caps.
Ouch!
Those caps were originally fixed onto metal chassis directly by nylon cable ties. After I was shocked, I cut those cable ties & put some more thich cardboard between caps & sheet metal, then re-fixed them. As the thin heat-shrink film seems vulnerable.
Old 5th September 2006, 11:43 AM   #5
Klimon is offline Klimon  Belgium
True, but ungrounded, touchable, conductive elements are only dangerous when high voltage carrying wire gets loose and makes contact with the element. There's usually no high voltage around the volume control...
Simon
Old 5th September 2006, 06:08 PM   #6
Tom Bavis's Avatar
A metal knob on a volume control is connected with the shaft, which has a sliding contact with the case, which is mounted to the metal chassis... so it IS grounded. If the pot's case ISN'T grounded, expect hum problems...
Old 5th September 2006, 07:37 PM   #7
rdf is offline rdf  Canada
rdf's Avatar
One general caveat I recently discovered, grounding a metal-bodied signal cap should be considered carefully. A coupling position isn't likely with an ASC but it's common with Russian Telfons, K40Y-9 PIOs and Russian silver mica. A Fluke DVM measured a whopping 70pf between either terminal and exterior case on the latter. That equated to (a probably not very linear) 70pf shunting the driver to ground in my amp. Even though it measured flat floating the cap body still cleaned up the sound significantly.
Old 5th September 2006, 10:31 PM   #8
so the good idea is to ground it to AC?
Old 6th September 2006, 01:34 AM   #9
Tubelab_com's Avatar
If the cap is inaccessible to the user, leave it floating, and keep low level signal leads away from it. If anyone can touch it GROUND IT. The can will often collect enough electrons to zap you. If it internally shorts, it can kill you.
Connecting the can to an AC ground will still put the previously mentioned 70pF to ground.
I have received the same unwanted experience from some Panasonic electrolytics. The big ones have a plastic cover over the can. The 100uF 350 volt ones do not, and the can will shock you.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 6th September 2006, 02:50 AM   #10
rdf's Avatar
Hi tubelab. In situations where the cap is in the signal path and the capacitance to ground a detriment, what do you think about using a bleed resistor? 70 pf in series with half a meg might be fine.
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 4 18th March 2014 09:42 PM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
Metal dome should always go with metal cone? Is this a rule? Jay_WJ Multi-Way 5 5th February 2007 06:53 PM
Metal Oxide vs flamme proof vs metal film ostie01 Parts 28 26th June 2006 06:38 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Copyright 1999-2017 diyAudio
