Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th September 2006, 02:27 AM   #1
Default Yamaha CA-series / CT-series parts
Hello everyone, I wonder if anyone of you got a parts unit CA or CT-series Yamaha amp or tuner??
I need two top cover screws, and a CA-1010 / CA-2010 wood cover.
Antoine
http://dmsaudio.ca/
Old 7th September 2006, 06:37 AM   #2
Nanook is offline Nanook  Canada
Nanook's Avatar
Default DragonMaster..
surely a guy like you can make something or salvage covers from a thrift store find?
Wood is best:-)
stew -"watch out where the Huskies go and don't you eat that yellow snow"--Nanook died of starvation 8 mos after the movie was made
Old 7th September 2006, 08:03 AM   #3
Geek's Avatar
I have Yamaha's all over here and they take the same generic little black mystery metal screw everything Asian since 1970 and later has been made from. Easy thrift store find
Old 7th September 2006, 04:09 PM   #4
I talk about the large cover screws.
http://dmsaudiocorp.deep-ice.com/yam-ca2010/screwr.jpg
The cover could be re-plated probably.
I also need some speaker terminals, one channel's positive is broken.
http://dmsaudiocorp.deep-ice.com/yam-ca2010/speaker.jpg
Anyone has a small bracket with the threads for the rear cover screw? And the spacer for the front one?
See :
http://dmsaudiocorp.deep-ice.com/yam-ca2010/leftin.jpg
(These are missing on the right side of my amp)
Antoine
http://dmsaudio.ca/
Old 8th September 2006, 08:05 AM   #5
EchoWars's Avatar
403 Forbidden
You must supply a local referer to get URL '/yam-ca2010/leftin.jpg' from this server.
Old 8th September 2006, 08:46 AM   #6
Geek's Avatar
Just hit reload or copy/paste the URL. It sees the browser referral as a hotlink.
I still emphasize scavenging. If you want those screws new, maybe a Keystone distributor or Acklands-Granger. As for the brackets, they made 4 million brackets to go with a million chassis and they aren't sold seperately
Old 8th September 2006, 04:05 PM   #7
If someone had an unrepairable or parts unit...
Antoine
http://dmsaudio.ca/
Old 8th September 2006, 08:34 PM   #8
Nanook's Avatar
Default parts chassis....
Dragonmaster.. ok, enogh stuffis "missing" from your unit that maybe a part piece would make sense.
The wood case (I think it is on those units), could be sanded with a sanding block to get absolutely smooth and flat, the refinish them. As far as screws, ets, the screws should be available on any Yamaha chassis orthe same era, if not try someone like "The Bolt Supoply House" (Canadian). All they do are fasteners, and you guessed it, mainly threaded ones).
wish I could help further, but if I do see one of the old Yamahas as a parts piece, I 'll try to snag it for you.
Old 8th September 2006, 09:43 PM   #9
Geek's Avatar
MCC Thrift, Value Village, Sally Ann....
Old 19th January 2007, 08:48 PM   #10
OK, now about every inputs have only one or the other channel working. (Only AUX and PHONO 1 work with both channels)
Guess it's time to clean the selectors!
I should use DeoxIT and DeoxIT Gold(or SHIELD?) I suppose? (I still haven't bought any of them)
An other problem : When the room is cold, the amp won't start : The relay keeps clicking, with a strange squeal when activated. After a couple of seconds it finally starts with a continuous squeal(not through the speakers, from the amp itself) that stops after a while.
Also, there are some intermittent silent scratches / pops even when the preamp is off, I suppose it's due to transistor solders on the amp PCBs?
Antoine
http://dmsaudio.ca/
Three 10" 4Ohm subs, wired in series or series-parallel? Nagamitsu Car Audio 24 10th May 2009 04:24 AM
Free parts Sony TL series spekaers - worth the trouble? ALustyGhost Multi-Way 0 15th December 2008 04:24 AM
hafler DH-100 series 2 vs non series 2 dimitri_dimitri Solid State 1 7th May 2006 10:48 PM
Quality of Hammond 300 series power transformers compared to 200 series? G Tubes / Valves 8 21st September 2003 03:27 PM
Fostex Z series, and EZ series? bbaker6212 Multi-Way 0 13th June 2002 01:10 AM
Page generated in 0.13310 seconds (74.48% PHP - 25.52% MySQL) with 10 queries
