| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I found this transformer in RS.
Here's the datasheet: http://img392.imageshack.us/my.php?i...titled2oa6.png I'm wondering how does that affect the voltage on the secondary. Thanks for the help |
#2 |
Imagine this resistance as a resistor in series with the winding. Voltage will be dropped on this resistor, depending on the current drawn, and can be calculated in the usual way.
In cases where the current drawn is fairly constant, such as with single ended circuits, there is little to worry about apart from the small loss of voltage. Generally speaking, class AB stages tend to perform better when the source resistance is as low as practical. |
#3 | |
I understand the voltage loss due to DCR. but how about specs such as regulation/iron loss? Thank you. |
#4 |
I do not see the the full VA rating. But, 84% efficiency and 10% (or so) regulation would not be considered impressive or even typical. It is true that smaller transformers are generally less efficient than their bigger brothers... this is really only because of manufacturing economies.
For example, a big mains trans for a building might have 98-99% efficiency. You can do better. Efficiency is not the main issue, but regulation can be depending on the nature of your load. |
#5 |
it's rated 50VA.
#6 |
#7 |
Jathel,
The efficiency sounds about right for a little guy... I guess. The questions would be then: 1) are you using it at full rating, and will it deliver the required secondary voltage? 2) is your load constant? If so, then regulation becomes less important. |
#8 | |
2. load is fairly constant. the load will be tube heaters so it'll be just like have resistors as load at the end. |
#9 |
You're fine then...
Also paralleling the secondaries will reduce the effective resistance by 1/2... it's a good thing. |
#10 | |
I would then use a low-voltage drop regulator (LT1084) between the 1st cap and the load. still enough? simulation (using simetrix or switchercad)says it will be enough if I do get the 9V or more on the secondaries. |
| Can resistor i-v voltage be compared to MC output? What transformer specs? | homemade | Digital Source | 11 | 22nd August 2007 02:26 PM |
| How to lower the secondary voltage of a transformer | myfavoritething | Power Supplies | 3 | 20th December 2006 10:30 PM |
| help with transformer secondary voltage reading | jarthel | Parts | 6 | 17th September 2006 11:48 PM |
| Filament voltage and affect on Rp | Jeb-D. | Tubes / Valves | 10 | 27th July 2006 09:13 PM |
| Page generated in 0.09698 seconds (82.09% PHP - 17.91% MySQL) with 10 queries |
