| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm going to investegate this anyway but...............
I'm going ahead with mounting a pair of piezo sounders under the bridge of my 5 string bass as pickups. Now, they vary in size and resonant frequencies 9KHz at 12mm down to 2.8Khz at 35mm. Do you think it matters as long as I don't mix them ( or should I mix them? does bigger make more out put? I will post this on the talkbass forum but to be fair, most of us are bass players, not Electronic designers. |
#2 |
Piezo sounders have a very high mechanical Q for high efficiency
#3 |
meaning?
#4 |
Your frequency response will be very poor... something like the skyline of Paris; a big spike in the middle.
#5 |
you mean if I do it at all, or just if I do one of the possibilities?
#6 |
Sorry, but I don't follow you.
No reason not to try... unless you're going to take router and chisel to your bass! |
#7 |
They're high Q when in their intended packaging, but when clamped between a bridge and body they're much lower Q.
#8 |
I've used them as pickups,but tied directly to the strings..
They worked okay,and have a decent output,even into the lower freqs (this was a 4 string bass-guitar-type setup) I bought a bunch of the raw discs at the local surplus place,no plastic housings or anything like that around them. |
#9 |
I tried it. It was ugly. With the elements between the body and bridge, it picked up as much body noise as string sound. Just stroking the neck was audible.
I will try the piezo idea again but I think I'll go for a factory bridge. No more playing arround. Baby has to work for a living! |
| Electrostatic Transducer ? | poynton | Planars & Exotics | 0 | 21st January 2008 05:16 PM |
| Piezo Transducer Trigger 4A Analog Simmons Drum Module | modorange | Instruments and Amps | 8 | 21st December 2007 04:23 AM |
| Low Pass Filter in line with a Piezo Transducer | ShaunL | Parts | 0 | 15th June 2007 04:52 AM |
| Transducer | nestor | Parts | 1 | 23rd October 2004 03:49 AM |
| Page generated in 0.09285 seconds (78.57% PHP - 21.43% MySQL) with 10 queries |
