Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Going to try winding a voice coil
Old 30th August 2006, 05:57 PM   #1
johnthedoctor is offline johnthedoctor  England
Default Going to try winding a voice coil
Got given some Wharfedales with the drivers o/c, have dismantled one and fancy having a go at rewinding the voice coils. The bit of coil I've pulled off has 17 turns in 3.5mm of width, so about .020mm including varnish. What gauge is that?
Old 30th August 2006, 09:48 PM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Good luck. I'll be very interested in your progress...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th August 2006, 10:25 PM   #3
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Default Re: Going to try winding a voice coil
3.5MM/17=0.2059 ~0.008" = 32AWG assuming the varnish is very thin and doesn't add much to dia. It could be 33AWG =0.0071" dia.
Jeff
Old 30th August 2006, 11:05 PM   #4
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Good luck!
The voice coil needs to be pretty tight on the VC former, so you may well need to make a circular jig that just slips inside, that will stop it distorting as you wind.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 31st August 2006, 02:36 AM   #5
rjb is offline rjb  New Zealand
The voice coil must be both tight on the former. and the combination perfectly circular when finished. You will definitely need a very smooth rod that just slides into the existing former, (or some similar removeable jig).
You will not be able to make it circular after winding if you get it wrong.
Use only enough tension on the wire to keep it firm on the former.
(You may need to grease the rod, because the winding pressure will tend to shrink the former, but be very careful to keep grease off the winding side of the former itself, (use only a very light smear), or else the glue used to fix the winding into place won't take).
Good luck
Old 31st August 2006, 02:52 AM   #6
PB2 is offline PB2  United States
PB2's Avatar
I did it years ago with excellent results. The first was a Dyna A-25
woofer, this was for Phillips AD8060 woofers:
http://members.aol.com/basconsultants/hand_vc.htm
One mistake was that the former was slightly thicker than the original,
and it was a tight fit. Most hobby shops in the US carry very thin stock
sheet of aluminum and often brass. I used copper to match the thermal
properties of the wire. Be sure to use the correct gauge wire.
The wire now comes in different grades with different temperature ratings
as I recall.
I used high temp two part epoxy.
Pete B.
Old 31st August 2006, 08:16 AM   #7
that's a very short VC @ 3.5mm.
Is it overhung (bass/mid) or underhung (treble and some mid)?
Looking forward to your solutions, conlusions and pics.
regards Andrew T.
Old 31st August 2006, 02:48 PM   #8
Thanks all for the help.
The 3.5mm is only part of the coil that I pulled off the former. Total coil is about 28 turns, single layer. Have a bad feeling that the cone has to be removed but will try doing it with the cone intact. 4 bolts holding the magnet to the basket so hoping there's enough play there for adjustments.
Wasn't expecting such interest in my progress, I'm a noob at diy audio and the drivers are dead anyway but I'll take pics as I go along for a 'How Not To' guide.
Old 31st August 2006, 03:02 PM   #9
phase_accurate is offline phase_accurate
Years ago I used to do this with the cone still attached to the coil-former. I removed the dustcap since it made things easier (especiallly the centering afterwards). If I couldn't find an adequate rod I used shets of thin paper or film negative inbetween. You definitely need to glue the wire to the former in the end.
Charles
Old 31st August 2006, 04:49 PM   #10
DO NOT unbolt the magnet from the pole pieces.
Due to the very strong magnetic attraction it will be extremely difficult to re-centre the pole gaps which must be concentric.
If the magnet surface is not plane (mine is not) and the pole piece is plane then there is a gap which I imagine reduces the total flux across the gap.
Q.
Is it better to fill the pole piece to magnet gap with a magnetic fluid before bolting it all back up?
I have still to design a jig to keep accurate alignment while offering up the pole to the magnet.
regards Andrew T.
Going to try winding a voice coilHide this!Advertise here!
Voice Coil Burning adelphia83 Car Audio 7 13th November 2008 12:10 PM
Single Voice Coil Vs Double Voice Coil Subwoofer Workhorse Car Audio 6 12th April 2007 06:36 AM
ASV voice coil ? Nihilist Multi-Way 4 1st October 2006 07:16 PM
an amp for each voice coil? speekergeek Multi-Way 1 12th December 2003 02:31 AM
Source for coil winding wire Phil O.son Multi-Way 6 22nd October 2002 02:58 PM
Copyright ©1999-2017 diyAudio
