Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 27th August 2006, 11:23 AM   #11
rpapps is offline rpapps  Antarctica
Sy is on the right track.
If you connect two equal capacitors in parallel the charge will be shared equally (Law of conservation of energy).
Now V=Q/C so, in a perfect world, if you double C, V halves.
No violation.
In the real world, some energy is lost due to thermal dissipation and electromagnetic radiation in the connecting wires so the end result is slightly less than V/2.
Physics 101 people!
Reference:
Physics for Scientists and Engineers
Fourth Edition
Raymond A. Serway
Old 27th August 2006, 11:51 AM   #12
No violation.
Physics 101 people!
Reference:
Fourth Edition
Raymond A. Serway
rpapps:
Our trouble in the moment is that double C and half voltage DOES violate the law of conservation of energy. Half of the original energy is lost.
Which is also plausible, because if split two double C and half V the unchanged amount of charge is placed on lower potential. Less energy.
The funny thing that we are loosing the energy even with a theoretically lossfree charge changing model.
If you want to split the energy onto two caps without energy loss, you would need an addiotinal ideal choke and some ideal switches.
...resulting in a nice energy transfer and then the voltage in each cap would be something like 70% of the original volatge.
This resonant event would nicely match to the law of conservation of energy, but would somehow violate the law keeping the amount of charge constant.... charge is then more afterwards, but we did not supply external charge... strange world !
Old 27th August 2006, 11:55 AM   #13
Sorry chocoholic, I don't see it and I can't read your scans to verify the math.
Cheers
Rob
Old 27th August 2006, 12:14 PM   #14
Our discussion is based on the following phenomenon:
Imagine two caps, both 1F.
In the beginning Cap1 is charged to U1=2V.
Cap2 is uncharged:
Total energy in the beginning E1+E2 = 1/2 x 1F x (2V)^2 + 0 = 2J
After connecting the second in parallel, both caps are charge to half of the voltage:
Total energy in the end: E1+E2 = 1/2 x 1F x (1V)^2 + 1/2 x 1F x (1V)^2 = 1 J
Old 27th August 2006, 12:28 PM   #15
Originally posted by SY
Here's an analogy that (at least for me) clarifies things. Imagine your first situation, a cap with a voltage V and a charge Q. Now, move one of the plates closer to the other to increase the capacitance...
Hi SY,
I think in your example things are less strange.
Due to opposite charge on both plates there is mechanic force, which is pulling together both plates.
If we now make one plate movable (and free of friction), we could use this force to pull something up. Mechanical energy can be calculated by increased mechanical potential energy or by integral of F (ds).
Old 27th August 2006, 12:33 PM   #16
Hmmm
I shall have to think about this.
Hopefully not for 7.5 million years.
Bedtime here, back tomorrow.
Cheers
Rob
Old 27th August 2006, 01:18 PM   #17
Joules is offline Joules  United States
Joules's Avatar
Dude --- You keep assuming the voltage will be cut in half by adding a second capacitor in parallel, but there is no law to prove that it will.
The law of consevation of energy is real. so based on that, the problem is
> 1 capacitor - .5(1F)*(2v)^2 = 2 joules
> 2 capacitors - 2 joules/(.5(2F) = sqrt of 2 or 1.414 Volts shared on bothe capacitors.
a simple reverse check > .5(2F)*(1.414v)^2 = 2 joules
Old 27th August 2006, 01:38 PM   #18
SY's Avatar
Y'all have to work harder on this one...
edit: ok, I'll give you yet another way to think about the problem. Your capacitor is charged, then we insert a chunk of dielectric with k = 2.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011
Old 27th August 2006, 03:18 PM   #19
How about answers, not questions?
I would guess that in this case the voltage will drop to 70.7%, but that's just a guess.
Let us know your view.
P.S.
No comment on my 'integral F ds' from your previous question?
At least your own answer to this question might help us.
Joules:
Besides conservation of energy, there is also a law of constant charge... Both laws seem to contradict here.
Old 27th August 2006, 04:37 PM   #20
poobah is offline poobah  United States
poobah's Avatar
Alright SY... poop rolls downhill and only downhill.
rpapps... the rub here is that V = Q / C, & E = Q^2 / (2 * C)
In this example charge must be conserved, energy as well, no one said the enregy had to stay in the caps though.
NFB net gain or loss rick57 Tubes / Valves 18 10th June 2005 11:26 AM
tragic loss of mdf... nerd of nerds Multi-Way 11 26th February 2005 02:08 AM
NEED HELP NOW! reg. loss in induktor. TroelsM Class D 2 6th January 2005 12:20 PM
At a loss... cunningham Class D 21 23rd September 2004 07:29 AM
Page generated in 0.12139 seconds (85.79% PHP - 14.21% MySQL) with 11 queries
