Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th September 2006, 03:56 PM   #141
anatech is offline anatech  Canada
anatech's Avatar
Hey poobah!,
just need some TIME is all
I said that already!
-Chris
Old 12th September 2006, 05:29 PM   #142
poobah is offline poobah  United States
poobah's Avatar
Old 12th September 2006, 05:57 PM   #143
jneutron's Avatar
Originally posted by poobah
This method looks at the before and after, but not the "during".
It is only "during" that energy can be lost..so, that has to be it..the alternative, is that energy is lost arbitrarily during the transfer via series resistance and the flash energy. Arbitrary loss will not produce the half voltage result obtained which is consistent with charge conservation.
You of all people should have the superconductors, perfect switches, and scopes with 0 seconds/grat sweep speeds to analyze all this... do it at lunch... will you?
I had considered it, but there are some details that need to be worked out.
1. The flat plate capacitors have to be superconducting. They have to be of sufficient current capacity that a quench does not occur during the transfer.
2. An inductor must be used to limit the possibility of quenches. The inductor must be toroidal, as external fields will couple to the environment.
3. A superconducting shield around the system is needed to prevent external transmission. This raises an additional problem, which is persistent currents. This will require raising the temperature slowly after the experiment, to measure the helium heat rise when the persistent currents quench out. Note that this problem will also affect the toroid.
4. With an ideal inductor and two ideal capacitors, the oscillation will proceed unhindered forever. The only entity which will slow it down would be eddy currents in the surrounding volume.
5. The capacitor will have to be rather large to provide any reasonable capacity..Liquid helium dielectric constant is not very high, and other materials are not well characterized at that temperature.
6. Current temperature sensors are only capable of a millikelvin or so of resolution, so the heat capacity of the helium may render temperature rise measurements of persistent current energy below the system resolution.
7. Silicon switches are very odd in liquid helium...Regular PN junctions have forward voltage drops of between 8 and 30 volts, you have to warm them to 20 kelvin or so before they begin to conduct again.
Cheers, John
Sheesh, a lot of writing involved in this chop-busting post..
Old 12th September 2006, 06:06 PM   #144
poobah's Avatar
You ain't bustin my chops. You just threw in the prerequisite L (or R) that I have been maintaining is the sucker punch in all of this.
Old 12th September 2006, 06:32 PM   #145
kvholio is offline kvholio  Netherlands
kvholio's Avatar
LOL, i got a pretty strong hunch it was a sucker-punch-brain-teaser when i found the exact experiment in the Dutch wikipedia.
It was under the category "anomalies in physics"
Gotta run guys. Got a worp-core breach on my hands
Klaas
Old 13th September 2006, 01:51 PM   #146
Hi Klaas,
I cannot access wikipedia from here. ...would be glad if you could send me that wikipedia essay by mail.... Oehem... only dutch? urghs..!
Old 15th September 2006, 10:51 AM   #147
long thread, i take it everything has come up roses?
another related, an more beleiveable form of this problem (that doens't violate the charge sharing stuff or involve infinate current) is:
charge 2 caps in parallel to 100V each.
remove both.
attache these in series.
if only it could be used for good, not evil...
Old 15th September 2006, 01:06 PM   #148
jneutron's Avatar
remove both.
It is not exactly the same.
Two caps in series, 1 farad each, 10 volts.
E = 1/2 C V2
in parallel,
C = 2, V = 10, E = 1/2 *2 *100, or E = 100 joules
then, put them in series
C = 1/2, V = 20, E = 1/2 * 1/2 * 400 or E = 100 joules
No loss.
(I was thinking of this scenario also...great minds think alike, right?
Cheers, John
Old 15th September 2006, 01:30 PM   #149
SY's Avatar
But John, you know that on inspection because the charges can't move.
If you want to have fun, you can make the energy "disappear" by connecting them back-to-back.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 15th September 2006, 01:43 PM   #150
jneutron's Avatar
yup, I simply pointed out the conservation of energy.
It was stated that ""another related, an more beleiveable form of this problem "", I pointed out the difference.
Apparently we have different ideas of what constitutes "fun"
Cheers, John
NFB net gain or loss rick57 Tubes / Valves 18 10th June 2005 10:26 AM
tragic loss of mdf... nerd of nerds Multi-Way 11 26th February 2005 01:08 AM
NEED HELP NOW! reg. loss in induktor. TroelsM Class D 2 6th January 2005 11:20 AM
At a loss... cunningham Class D 21 23rd September 2004 06:29 AM
Page generated in 0.12991 seconds (74.73% PHP - 25.27% MySQL) with 11 queries
