Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 26th August 2006, 02:24 PM   #1
jarthel is offline jarthel  Australia
Default fuse before AC switch?
I've read suggestions from other people saying to put the fuse before the AC switch.
any reason behind it?
thank you.
Old 26th August 2006, 02:39 PM   #2
I would go along with fuse first.
That way anything downstream that goes faulty and draws excessive current is protected by the fuse. The fuse won't save the faulty component and probably not limit consequential damage either, but will stop the mains cable catching fire and worse.
There are some models of IEC inlet and inlet filters that are fused. They always (well nearly always-but I have never seen an example) have the fuse first.
regards Andrew T.
Old 26th August 2006, 03:22 PM   #3
quasi is offline quasi  Australia
quasi's Avatar
I agree with AndrewT. The fuse should be the first termination point for the active mains connection. I always go to the fuse first, loop then solder the connection. I then go from the other side of the fuse to a terminal block and feed components from there.
Cheers
Quasi
Stinger RCA Cable and Fuse Switch (and other random cables) aemixes Swap Meet 1 27th April 2009 11:09 PM
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 11:39 AM
where to buy iec power jack with switch and fuse neil_kaye Parts 3 5th January 2007 01:37 AM
Why main fuse and not rail fuse? digital desire Solid State 10 3rd December 2006 09:07 PM
amp rating for fuse and fuse holder? riotubes Parts 5 27th August 2006 04:10 AM
Page generated in 0.07477 seconds (71.42% PHP - 28.58% MySQL) with 10 queries
