Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Mil spec wire?
Mil spec wire?
Old 10th December 2002, 07:01 PM   #1
Joel is offline Joel  United States
Joel's Avatar
Default Mil spec wire?
Has anybody tried the Alpha military spec wire they sell at Mouser.com?
I'm wondering if it's worth the extra $$$, as far as heat and abuse resistance.
Old 10th December 2002, 07:03 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Dunno Joel,
I'm sure you'll let us know what it "sounds" like
Old 10th December 2002, 07:05 PM   #3
dorkus is offline dorkus  United States
dorkus's Avatar
Send a message via AIM to dorkus
what kind of wire is it?
i'm not sure what the Mil spec is for but yeah, probably things like tensile strength, dielectric breakdown rating, and heat resistance. all things not particularly important for audio.
i would make your wire choice independent of the Mil spec or what not. if it's good, it's good wire, regardless of spec. or it could be crappy wire and Mil spec.
is this stranded silver-plated copper with teflon insulation?
Old 10th December 2002, 07:28 PM   #4
Philo is offline Philo  United States
Generally, milspec includes those requirements, especially heat resistance. In the Navy, most data carrying wiring is now required to be teflon or better insulated, including CAT5(plenum). Internal wiring for for electronic equipment is also silver plated. Nice stuff to work with, and have used it on some small audio projects, but I haven't had a chance to compare it sonically.
Philip
"If you didn't make it with your own two hands, its not really yours".
Old 10th December 2002, 08:59 PM   #5
Joel's Avatar
Originally posted by dhaen
Dunno Joel,
Yeah, I will John. I hope it's extra juicy.
Old 10th December 2002, 09:22 PM   #6
sam9 is offline sam9  United States
sam9's Avatar
The reason for a lot of the mil-spec requirements is to insure continued functioning while subject to dire and extreme conditions. The Navy also is concerned with esposure to high humidity/saline environments. If this decsribes your situation perhaps you want to consider moving to a different neighborhood.
Old 10th December 2002, 09:28 PM   #7
Bas Horneman is offline Bas Horneman  Netherlands
Bas Horneman's Avatar
What is the mouser part no?
Old 10th December 2002, 09:32 PM   #8
LOL! So true, Corrosion is very much an issue but unfortunately it is usually from condensation. Because most shipboard equipment is high power we cool the hell out of everything. We also dry the air but moisture gets in and condensate forms on the equipment. The biggest concern is the ability to remain operational in a battle so shock and heat resistance are primary concerns. If you can get it cheap like I can, use it, but don't spend the extra bucks for it unless your sure of the benefit.
Philip
Old 13th December 2002, 03:47 PM   #9
Joel's Avatar
Bas, it's 602-1855/19-100-06 (description:22G MILW16878E)
Basically, I just wanted something that wasn't going to get all funky when you solder it, and the 600V rating is nice. Seems about 80% of the hookup wire sold by dealers is only a 300V rating... not so good for a tube amp maybe.
Old 13th December 2002, 03:51 PM   #10
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Mil spec wire? Send a message via AIM to Peter Daniel
Joel,
I've just noticed some suspiciously expensive capacitors in your new avatar.
www.audiosector.com
Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it. - JC
Mil spec wire?Hide this!Advertise here!
litz inductor wire for speaker wire. fazman Everything Else 126 20th June 2011 02:48 PM
wire spacing for stretched wire ESL? Few Planars & Exotics 9 26th March 2009 12:37 AM
22 AWG silver plated solid copper wire for speaker wire? G Full Range 21 15th February 2009 09:32 PM
magnet wire (not sure of the term) used as chassis wire? jarthel Parts 8 27th September 2006 09:50 PM
How to wire a Ixos Gamma 7 bi-wire cable mangalchacha Multi-Way 1 13th April 2005 02:58 PM
