Mil spec wire? - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th December 2002, 11:10 PM   #21
diyAudio Moderator Emeritus
Bas Horneman's Avatar
I use belden cat5 teflon isolated wire...got it really cheap..3 of the 4 tp are teflon and 1 tp is pvc... but that was a one off buy...the shop where i got it has got none left..
but any hookup with solid core is good enough imo..
the coax that has air as dielectric should be ideal..except it is ungainly in use..
Old 14th December 2002, 04:32 PM   #22
MRehorst's Avatar
Isn't "Hospital Grade" supposed to sound better than "Mil Spec"?
MR
Old 15th December 2002, 05:06 PM   #23
MRehorst's Avatar
I picked up a lot of Teflon insulated wire on ebay for what came out to $0.03 per foot including shipping. The stuff is there all the time. Search for "teflon wire".
I can't say it "sounds" better (I seriously doubt it) but is sure does solder better. Teflon insulation doesn't melt like PVC, so you get good, nice looking solder joints every time.
MR
Old 16th December 2002, 04:09 PM   #24
Apex Jr is offline Apex Jr  United States
Default Mil-Spec Wire Spec's
Someone spoke of the Mil 16878 spec.
For information
Mil 16878/ 4 is standard E Teflon
Mil 16878/ 5 is heavy wall Teflon
Mil 16878/ 6 is thin wall Teflon
each type can come in either 7 strand but mostly
19 strand
Steve
Old 16th December 2002, 04:18 PM   #25
pinkmouse's Avatar
I have loads of reclaimed wire I use for projects, as well as stuff I specifically buy. Is there an easy way to work out if any of my surplus stuff is Teflon?
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 16th December 2002, 04:22 PM   #26
dorkus is offline dorkus  United States
dorkus's Avatar
Send a message via AIM to dorkus
just stick your iron on it for a few seconds and see if it melts.
once you see teflon, it's hard to miss it. it tends to be very hard and tough compared to other insulations, often but not always with a semi-glossy finish. it does not stretch much either.
Old 16th December 2002, 04:33 PM   #27
Default Teflon wire touch
When you touch teflon with your fingers it has a smooth
and destint feel. You'll know when you feel it.
Regular PVC is hard feeling and can feel rough.
Steve
Old 16th December 2002, 04:54 PM   #28
MRehorst's Avatar
Teflon insulation has an almost greasy feel to it. It is hard to strip with a regular wire stripper because it takes a lot of force to cut it and you usually end up cutting some of the strands of wire with it, especially the 19 strand stuff. It is hard to cut the insulation cleanly so you end up with little whiskers of teflon attached to the ends of the wires.
If you're going to use a lot of teflon wire, do yourself a big favor and get a thermal stripper. It will cleanly melt through the teflon without damaging the wire underneath. You can pay top dollar for a thermal stripper if you get it from a tool company, or you can look for one on ebay or at a ham fest. I picked mine up for $10 at a flea market.
MR
litz inductor wire for speaker wire. fazman Everything Else 126 20th June 2011 02:48 PM
wire spacing for stretched wire ESL? Few Planars & Exotics 9 26th March 2009 12:37 AM
22 AWG silver plated solid copper wire for speaker wire? G Full Range 21 15th February 2009 09:32 PM
magnet wire (not sure of the term) used as chassis wire? jarthel Parts 8 27th September 2006 09:50 PM
How to wire a Ixos Gamma 7 bi-wire cable mangalchacha Multi-Way 1 13th April 2005 02:58 PM
Copyright 1999-2017 diyAudio
