Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Mesurement electret mic problems
Old 24th August 2006, 10:53 AM   #1
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
Default Mesurement electret mic problems
A few days ago i got a JBL measurement microphone from LSR4300 monitor set. The mic was designed to work with these speakers(the speakers are active and have mic input to equalise frequency responce automatically).There is +15V written on mic jacket on speakers.
I want to be able to connect this mic to a sound card.
I disassembled the microphone cover, and found a few components inside.The is one IC , JRC 4580(or 5616?) , and a few caps and potentiometer.
On the little PCB , there are three connections(Vcc , Gnd , A-Out).The VCC is 15 Volts , ground is ground , and A-Out i suspect to be audio out.The +15V is red on mic's minijack , white is A-Out , and ground is shield. The two other connections go to mic capsule.
So , this is mic amp.
I built a little regulated +15V power supply , and connected it to the minijack of microphone.It works, but i am having lots of 50 Hz Hum in SpectraPLUS ... Ground loop ? Touching the microphone increases this hum. I tried to replace the regulated PSU with 9 volt battery , but the things didn't change , so it is not supply's fault.I included the connection block diagram.
Lukas.
Old 27th August 2006, 03:13 PM   #2
Bazukaz's Avatar
So, no ideas ?
I also observerved that touching the microphone's case together with PC case while holding peace of wire diminishes the hum almost completely.
Lukas.
Mesurement electret mic problemsHide this!Advertise here!
Mesurement tools for sound. King Nothing Everything Else 0 19th December 2008 02:37 PM
Max spl of electret capsule Circlotron Analog Line Level 24 20th February 2008 08:32 AM
4-pin mic converted to a 2-pin electret mic? silentblackhat Solid State 1 10th January 2008 06:50 PM
electret Mic preamp teopoz Chip Amps 10 14th October 2007 09:19 AM
speaker response mesurement AR_sound Multi-Way 0 15th April 2006 07:17 PM
