| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm doing My Project is "Computer semiconductor characteristic curve" (My english is bad.So Just Show the test result.)
My project link(China) is http://www.hifidiy.net/bbs/boke.asp...owtopic.92.html This instrument can test MOSFET / JFET / transistor / diode / SCR / resistance.... It can display the 1."Ic->Hfe" curve Example 2SA733(PNP) "Ic->Hfe" curve: and 2SA1386's "Ic->Hfe" curve: 2."Vbe(Vgs)->Ic(Id)" curve example MTH15N20 "Vgs)->Id" curve 2SK246 Vgs->Id curve 3."Vce(Vds)->Ic(Id)" curve example 2SC3519's "Vce(Vds)->Ic(Id)" curve IRF9610 "Vds->Id" curve 4. 3-Terminal Regulator's Vi-Vo curve Example 78L05 The Project use to matching Devices is very excellent this pict show how to match 9 pair 2SK246s,It Test 9 2SK246s and Show their Vgs-Id curve from the pict,you can see the 4 & 6 curve is match, and the 2 & 5 is match. By this way ,you can match device precision. The project use 5 integrate circuit, They's: 1 chip LTC1090(8 channel 10Bit ADC with SPI interface) 1 chip M62359 (8 channel 8 Bit DAC with SPI interface) 3 chips TDA2030 as 3 channels(B C E) programme Push-Pull Power Supply 1 chip 74HC595 as control relay 1 chip TC4050 with PC interface buffer the instrument don't use MCU,just use PC's parallel port (LPT) to controle the DAC & ADC |
#2 |
Looks interesting.
#3 |
Locky-Z,
the link you posted to diyhifi.net does not work. Can you post the link again ? Are you willing to share the design, free or selling it ? (you guys should install the Chinese language into your operating system, lots of great stuff on diyhifi.net, including top parts) |
#4 |
the result is here
http://www.hifidiy.net/bbs/dispbbs.asp?boardID=2&ID=31462&page=1 the sch public here http://www.hifidiy.net/bbs/boke.asp?locky_z.showtopic.92.html but software is shareware. I have a little LTC1090 & M62359 chips, just only enought to develope and use for me. So the board is not sell. |
#5 | |
Not written in G or LabTracer ? |
#6 |
the Circuit
Measurement of the curve, including : BJT (including Optocoupler) : PNP NPN of Hfe->Ic curve (measurement of the curve is in constant Vce conditions) PNP NPN of Vbe->Ic curve (measurement of the curve is in constant Vce conditions) PNP NPN Vce->Ic curve (constant Ib) P-type or N-type MOSFET and JFET : Vgs - Id curve (under the conditions of constant Vds) Vds - Id curve (under the conditions of constant Vgs) Diodes / Regulators diode / LED positive, reverse curve positive and negative 3-Terminal voltage regulator IC: Input voltage->output voltage characteristic curve Output voltage->current characteristic curve liabilities also capable of measuring SCR trigger current, voltage trigger, pressure drop, maintain current parameters (not curve) Below are the same measurement a 2SC3519 high-power BJT curve Ic = 300-1800mA scope of Hfe ->Ic curve the IC=20-300mA scope of Hfe - Ic curve Ic=2-30mA scope of Hfe - Ic curve Ic=0.5-3mA scope of Hfe - Ic curve Ic = 50-700uA scope of Hfe - Ic curve The same 2SC3519 of Vbe-IC characteristic curve Ic = 100-1900mA Ic = 5-160mA Ic = 0.3-14mA Ic = 10uA - 1mA Just look again at the output characteristic curve Vce->Ic Ib constant measurement, Ib = 1-9mA Ib = 0.1-1mA Ib = 10uA - 100uA Ib = 1uA - 10uA
#7 |
Below are the same screen shows 12 pic 2SA1386 of Hfe - Ic characteristic curve and Vbe-Ic curve and Vce - Ic curve
By the same measurement conditions , you can show more Semiconductor's curve on same screen. From the screen ,you can match the most matching Semiconductor Below is the measurement IRFI740 Vgs from 3V to 3.9V step 0.1V. measuring the Vds - Id characteristic curv Below are the same measurement of the Vgs-curve Id (Id = 0-1700mA) Vgs-curve Id (Id = 0-25mA) Id = 0-1mA Measurement of P-MOS IRF9630 the Vgs->Id curve Measuring diode in a variety of different current of VF characteristics (1N5401 BYV32 FR305 1N4 001 MBR3060 1N4148) Measuring 6 V Regulators diode positive / negative characteristic curve
#8 |
At the same screen to display the JFET's Vgs->Id and Vds->Id characteristic curve (2SK 373GR)
Let's look at different suffix of 2SK246 the Vgs->Id curve (GR and Y suffix) Exchange the same 2SK246's D, S pin and measurement they Vgs->ID curve The system also is a characteristic of different polarity to contrast the characteristics of the tubes, For example, the following is the system provides functional polarity reversal and contrast 2SK246GR and 2SJ103GR the Vgs->ID characteristics curve
#9 |
Does anyone know of any active links for Lock_Z DIY curve tracer and software. This project looks like a cool unit for using at home with out all the major expenses of obtaining a curve tracer from E-Bay. If not does any one know of a project using a USB measurement unit-( the cheaper ones) for doing this with say relays on the digital control ports.
#10 |
The schematic had changed a little,see below.
the software can download from http://bbs.hifidiy.net/attachment.php?aid=246124 http://bbs.hifidiy.net/attachment.php?aid=246125 It is Chinese language version , only support one curve trace. the board no MCU so it not support USB interface,only support LPT interface |
| Intelligent switched in cars - ISO10483 | peranders | Everything Else | 1 | 3rd April 2009 07:14 PM |
| hello to all intelligent life forms out there | ampzillason | Introductions | 1 | 25th October 2008 03:19 PM |
| Computer semiconductor characteristic curve Project | locky_z | Everything Else | 4 | 4th May 2006 05:17 AM |
| Page generated in 0.24097 seconds (76.09% PHP - 23.91% MySQL) with 11 queries |
