| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have purchase some IRFP240 and 9240 from a distributor. When I try to match the 9240 by applying a 15Vdc and a 150ohm resistor in series with the D,S, I found some of them give me a steady ready of about 3.6-3.8V (+ or - doesn't matter) which is normal, but some of them (about 20/50) cannot sustain a steady voltage. Does it mean that these are leaking badly and are no good? I wonder if the distributor would do anything about it.
Thanks for shedding a light. |
#2 |
Seems if the ones you suspect are leaky they should show some current when Vgs=0v. If it's gate to drain leakage, stiffining your gate drive should reduce the effect you are observing. Finally, if it's leakage it will be affected by temperature. As your IRFxxx warms up the leakage will increase.
Classical-Audio.com |
| a leaking cap | simonwai999 | Parts | 4 | 18th August 2008 07:43 PM |
| Tube matching service - As found on Craigslist | Sal Brisindi | Tubes / Valves | 1 | 17th December 2007 04:10 AM |
| power fets, bias, gain matching & other stuff. | lowlevel | Solid State | 11 | 22nd January 2005 05:03 PM |
| Matching LTP FETs for Best Sound? | Dave S | Pass Labs | 3 | 23rd March 2004 11:16 AM |
| found TDA1541,1543, Japan FETs cheap | Werner | Parts | 6 | 3rd June 2003 12:19 PM |
| Page generated in 0.06479 seconds (73.26% PHP - 26.74% MySQL) with 10 queries |
