Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 20th August 2006, 04:22 AM   #1
artb is offline artb  United States
Default Replacing meters in bench power supply
I picked up a Sorenson SRL40-25 lab power supply from the Pratt and Whitney surplus store on Sat. I orginally I was hoping to get an oscilloscope but $10.60 for a PS, couldn't hurt to take a chance right? Voltage and current meters look a little worse for wear, especially the voltage meter. So here's my question(s) for the board: can I replace the analog meters with digital meters and if so what are some recommendations?
I haven't had a chance to actually plug it in yet cause it's a heavy mother.
thanks
art
Old 20th August 2006, 06:15 AM   #2
3.5 digit meters are fairly cheap.
Add a resistive attenuator to change the scale from 1.999V to 199.9V and just don't use the top half of the usable range (ruins sensitivity unfortunately). Maybe a press and hold button to temporarily decrease scale to 19.99V might be a nice to have). or buy more expensive 3.75 digit meters (4000 or 6000 count instead of 2000 count).
Similarly, add a current shunt to get your 1.999V scale to read the correct current.
Fit current and voltage meters, very handy.
regards Andrew T.
Old 20th August 2006, 11:19 AM   #3
dnsey is offline dnsey  United Kingdom
If you want to do it on the cheap, use a bargain basement multimeter (suitably adapted and powered).
Programmable Bench Power Supply? samsagaz Parts 1 22nd January 2008 02:21 AM
HV SS bench top power supply, advice needed panos29 Tubes / Valves 11 19th December 2006 07:06 AM
My new bench power supply Circlotron Equipment & Tools 7 28th April 2003 03:29 PM
bench power supply jethari Parts 1 14th March 2003 05:31 PM
My bench power supply.. deepanger Solid State 71 18th February 2003 07:56 PM
Page generated in 0.07872 seconds (63.97% PHP - 36.03% MySQL) with 10 queries
