Hi Jarthel
Poobah is correct for mechanical relays as they can produce a high reverse voltage across the coil when the current is turned off. The diode absorbs this and prevents damage to other components.
However, this is a solid state relay and does not produce the inductive kickback so no diodes are necessary. You are only switching current through a LED.
Cheers
Rob
Cheers
Rob
