Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
A/D Ground plane separation and common supplies
Old 15th August 2006, 11:21 PM   #1
rtarbell is offline rtarbell  United States
Default A/D Ground plane separation and common supplies
I am using a PGA2320 digital volume control pot for an amp; for its analog power supplies, I am using +/- 8V regulators fed via a wall wart.
Concerning the separation of digital and analog grround planes, I am trying to use just one main power supply (a 12V wall wart). I can get +8V analog from the 12V by a voltage regulator, and I can get -8V from the +12V wall wart by a charge pump (Microchip TC962 can take the +12V and turn it into -12V) and voltage regulator.
I can also get +5V for the digital controllers via a 5V voltage regulator. If I do this, will this violate the separation of analog and digital ground planes because the analog supply regulators and the digital supply regulator are being fed from the same wall wart?
Old 16th August 2006, 04:05 AM   #2
jcx is offline jcx  United States
usually analog and digital gorund are connected, there are just some considerations for where/how relative to signal inputs/outputs for digital and analog portions of the circuit
a solid ground plane with analog and digtial parts seperated as well as is logical would be a start, then performance may sometimes be improved slightly by putting some slots that partially seperate analog and digital ground planes except for one narrow neck of common copper
read all of the grounding tech notes you can find, some GHz speed layout techniques don't really translate to most audio apps but the principles are worth understanding
the 1st is that current always flows in closed loops - then consider that "ground" has impedance both AC and DC that converts ground return portions of the current loops into ground noise/common impedance coupling
the goal is to keep high current and high frequency "dirty ground" return currents from having/wanting to flow in the analog ground
A/D Ground plane separation and common suppliesHide this!Advertise here!
star ground vs. ground plane Sebastiaan Chip Amps 93 14th February 2017 12:41 AM
Ground domain separation borges Power Supplies 1 6th February 2008 09:40 PM
ground plane interference with output mazurek Solid State 0 17th August 2006 11:14 PM
Eagle PCB Ground Plane Question Algar_emi Everything Else 6 26th January 2006 03:36 PM
I discovered CDP ground plane. What should I do with it? DIAR Digital Source 18 4th December 2004 01:29 PM
Copyright ©1999-2017 diyAudio
