| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have the non-profit DAC TDA1541A kit which needs a 15v-0-15v trans (which is around 21v DC)
i'm wondering if i can bypass the use of transformer to use SLA battery instead... initally i plan to use 12v + 6v... but then the shop owner said it's not good to use different one... not sure why... how about 6v+6v+6v = 18v ? my questions 1) can i bypass the bridge rectifier by using 2 rails of 0-18v battery straight wire to the cap 2) 12v+ 6v (cheaper) or 6v+6v+6v (more expensive). Which one better ? 3) this DAC take less than 2A... wat criteria should i be looking on the SLA batteries ? i saw a 'AH'.. wat is that ? |
#2 |
no one ? i'm wondering if it is even possible to do this
#3 |
U can use 12+6 (batteries cheap) if both have same AH ie Ampere hour capacity..Different AH will result in lower AH battery getting depleted before higher AH batt.
Better to use 7AH or above ..so @2amps will give around 3.0hours backup. yes u can bypass the bridge and transformers..but what abt the charging of batteries ?
SivanandBalan |
#4 |
I have used batterys to power a 5 watt Son of Zen with realy good results. Using 12v +- @ 2A it was super easy to use a pair of 12v batterys. But it`s a real bummer to be enjoying the music and have the batterys go dead so I realy don`t recomend it.
| Can I replace transformer drive with optocoupler in halfbridge smps? | lakone | Power Supplies | 1 | 11th May 2009 02:20 PM |
| Need to replace the transformer in this amplifier | Kramerguy | Solid State | 35 | 23rd December 2008 07:54 PM |
| transistor circuit to replace transformer in ribbon mic? | ubertar | Instruments and Amps | 1 | 14th August 2004 09:42 AM |
| 3 pin li-ion batteries | Holger Barske | Parts | 1 | 12th May 2004 07:54 PM |
| Can a variac replace the power transformer | gnomus | Pass Labs | 9 | 18th December 2002 02:30 PM |
| Page generated in 0.07775 seconds (64.63% PHP - 35.37% MySQL) with 10 queries |
