Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Mill your LED's!!!
Mill your LED's!!!
Old 11th August 2006, 06:46 PM   #1
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Default Mill your LED's!!!
I was in need of a LED for a project and all I had on hand was various colors of 5mm LED's. The size of the LED didn't please my eye and I also didn't like how it threw off a focused beam of light.
Here was my solution......
Its very fast and easy to do. All I used was a cordless drill and a file. The LED lense material is easy to mill and also very strong. You can make it pretty thin without worrying about it breaking off.
I'm probably not the first person to think of this, but I havn't seen it done before.
Old 11th August 2006, 07:40 PM   #2
inuyasha44320 is offline inuyasha44320  United States
I LOVE IT!!!!!!!!!!!!!!!
i wish i had thought of that!
i think ill try that
Okay, so how do i put the smoke back in?
Old 11th August 2006, 08:42 PM   #3
carlsonmark is offline carlsonmark  Canada
Can you get a photo of that from an isometric view, please? Looks awesome from the side!
Old 11th August 2006, 09:07 PM   #4
Hope this is what you mean....
Old 11th August 2006, 09:27 PM   #5
Yes, that is what I meant. Looks good from that angle too.
I know at least one person who has done that before, but I hadn't seen it until now.
Old 11th August 2006, 09:31 PM   #6
Here is a pic of the amp I used it on. I had to pad it down with a 2k resistor, having all that light collecting in the small tip made a blinding sight.
The AMP3 based amp is a birthday present for my my lil' bro in the marines. Hope he likes it.
Old 11th August 2006, 10:52 PM   #7
cpemma is offline cpemma  United Kingdom
I flattened the top of a 3mm blue LED on my T-amp mod to kill the concentrated glare from in front, worked quite well. The dome shape is the main "lens" that determines beam angle on LEDs.
A guy called macroman at Bit-Tech drills holes into LEDs and fits a length of fibre-optic cable for a tiny point of light on such things as control knobs...he must have the touch of a midwife. That was first published Jan 1, 2002 so maybe pioneering.
btw, you can buy LEDs like the top one, "lighthouse" case down to about 2mm dia, though not in blue or white AFAIK.
Old 11th August 2006, 11:03 PM   #8
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
Very cool! It looks to be a very good way to turn the clear lens LEDs into something much more diffuse.
Brian
Old 12th August 2006, 12:05 AM   #9
Yes, the diffused look was ultimately what I was going for. I could have just sanded the end, but I also wanted something smaller than 5mm.
I know you can buy diffused LED's of different sizes, but this forum is about DIY!!! Not to mention I have about a bazillion 5mm clear LED's.
Old 12th August 2006, 01:12 AM   #10
rcavictim is offline rcavictim  Canada
rcavictim's Avatar
You guys know of course that LED is an acronym. It stands for light emitting dot .
"There are more worlds than the one you can hold in your hand." Albert Hosteen, Navajo spiritual elder and code-breaker, X-Files TV Series.
Mill your LED's!!!Hide this!Advertise here!
Tooling (lathe / mill) recommendations ? ckniker Analog Line Level 1 18th August 2007 06:20 AM
Proposal for a Sherline 5400 Deluxe Mill. DJ Exprice Parts 9 9th November 2006 12:51 PM
on ebay: new eminence beta cx and sherline mini mill mpmarino Swap Meet 0 2nd November 2006 03:08 AM
Less than 38.000 posts till the 1 mill Bakmeel The Lounge 1 6th July 2006 08:48 PM
