Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th August 2006, 03:25 AM   #1
Default PCB Maker Software/design
I know this has been review many forum thrread, but I need quick answer.
what's the easiest PCB Design software to create only less than 40 component ? with available componrnt library. ?
cal
be tube
Old 8th August 2006, 08:05 AM   #2
I find Express PCB easy.
I am stilllllll trying......... to get Eagle to work for me.
If you plan to make your own then Express has no downsides. Except on my laser it prints correct width, but -2% on height.
regards Andrew T.
Old 8th August 2006, 08:33 AM   #3
I think I need tutorial for that.
anyone can send me ?
cal
be tube
Old 8th August 2006, 07:16 PM   #4
traw is offline traw  United States
i've used custompcb.com with good results - can send them an eagle file(s) directly, no need to convert to gerber. as long as your design fits the 'free' version of eagle (or you own license). panelize reasonably.... if bigger board, maybe expresspcb.
someday may try ourpcb since if you get up in quantity, they become real inexpensive.
Old 9th August 2006, 02:15 PM   #5
thanks Andrew T and Traw for that link..
hmm when it's come to Audio, believe the connectivity of a PCB is important. i came by a chance of in a shop that makes 2 identical amp.
He did an A/B switching Demostration between both. one was using a normal PCB and the other was using a teflon or something board( or something that the master of the shop mentioned was exactly the same use by Audio research)..
and clearly the telfon something was better sounding...
didnt know PCB could make a differences..
what is your remcommendation?
i am still a noobs in DIY audio. thanks you
Old 11th August 2006, 02:12 AM   #6
The two boards will have different copper thicknesses, far more likely to have an audible effect than the dielectric material.
Old 11th August 2006, 06:34 AM   #7
the tube (valve) builders say that using PCB in lieu of hard wiring seriously degrades the sound.
regards Andrew T.
PCB Design Software BrianDonegan Parts 136 9th April 2007 04:19 AM
Need Design Software? dbaudio Swap Meet 2 15th April 2004 06:54 AM
Does anyone here use Ouickroute EDS 3 design pcb design software? setmenu Everything Else 2 18th March 2004 01:23 PM
Page generated in 0.08536 seconds (70.81% PHP - 29.19% MySQL) with 10 queries
