Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th August 2006, 05:58 PM   #1
mpmarino's Avatar
Default Hmm, what the heck am I gonna do with this??
Primary: 2 X 100v / 2 X 20v
sec. : 2 X 120v / 2 X 2500VA
50/60HZ
Can you say "inrush"?
Crazy Yankee.
Old 7th August 2006, 06:31 PM   #2
Did it Himself
richie00boy's Avatar
Are you sure you have the primary and secondary the right way round there?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 7th August 2006, 06:38 PM   #3
mpmarino's Avatar
The only way I will be sure is to test it. The label from Toroid Corp. of Maryland states exactly what I typed, however. This is definitely a custom job and I suppose it's possible the label is typo'd. I understand they were for some type of military radar assy.
There is another one like it where I got this, as well as a 2 X 2000va at the same voltages.
Crazy Yankee.
Old 8th August 2006, 12:53 AM   #4
Account Disabled
Send a message via AIM to classd4sure Send a message via MSN to classd4sure
I don't know about that 2X20 primary...????
Otherwise... sounds like it might make an OK isolation transformer?
Old 8th August 2006, 01:16 AM   #5
FastEddy's Avatar
Default still looking for ...
120 primary / 50 center 50 secondary for 400+ Watts ...
Got sources?
Old 8th August 2006, 01:25 AM   #6
Stuart Easson's Avatar
Send a message via MSN to Stuart Easson Send a message via Yahoo to Stuart Easson
Default the primaries make sense...
...For an international piece of equipment...
With the correct parallel/series combination of the 100,100,20,20 you can fulfill just about any nations voltage requirement (100, 120, 200, 220, 240).
Does this weigh like 25lbs? it's possible it really is a 2x2500va xformer, the thickness of the copper visible through the tapes suggest it has huge current rating, you could do a little surgery and center tap the 120v secondaries and get 60+60, 60+60 at some 20amps if it is a 5kw transformer...or just use it as 120+120 for a mighty powerful amp.
Looks like a pretty darn cool find...if a little large for some applications...
Stuart
Old 8th August 2006, 02:16 AM   #7
mpmarino's Avatar
That's a good point about the primaries stuart.
BTW. It weighs in at 79 pounds even.
Crazy Yankee.
Old 8th August 2006, 08:07 AM   #8
Stuart is spot on
Four 60Vac windings would be handy. Pity about the filled centre though.
You should still be able to test probe for the centre tap and make good any enamel damage before re-wrapping the outer insulation and all this without removing the core.
Would it be a waste to use as an isolating transformer 120 to 120 at a total of 5kVA?
regards Andrew T.
Old 8th August 2006, 12:41 PM   #9
Default unpotting...
...the centre is possible...
I bought a set of toroidal transformers from parts express last year, I wanted to rewind them and had the potted centre issue. After slitting the tape around the circumference of the transformer, you can use a piece of broom handle and a hammer to drive it from the centre of the transformer. The insulating tape has a low enough coefficient of friction it simply pops out...
Of course you need more tape to rewrap the thing after you rewind it...
Good luck
Stuart
Old 8th August 2006, 01:11 PM   #10
SY's Avatar
This would be very interesting as a power tranny for an OTL. Figure you'll get +/-170V or so, perfect for an array of 6528.
With a doubler, you could get 500V easy and build one whale of a big conventional tube amp.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
What the heck have I done..!? lazyfly Chip Amps 3 24th August 2004 09:27 AM
Where the heck?? Kengro Multi-Way 3 5th March 2004 06:26 AM
OK, whose gonna clone these? Jhovis Multi-Way 11 15th December 2003 11:41 PM
Aw, Heck Bill F. Introductions 12 24th April 2002 07:17 AM
Page generated in 0.12814 seconds (77.40% PHP - 22.60% MySQL) with 11 queries
