Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th August 2006, 03:12 PM   #1
macboy is offline macboy  Canada
Default NTE1869/NTE1869SM regulator?
Anyone know anything about this? The datasheet (like all NTE datasheets) is utterly useless. I bought this at a shop because i needed a small regulator and it's what they had. From what I can glean from the datasheet, it is more of a voltage reference than a regulator. Does anyone know how to create an actual regulator out of this? The 3 pins are labelled Input, Ground, and Reference (which is 1.26 volts). The datasheet mentions a PNP pass transistor and an R1, R2, and C1, but has no circuit diagram to go with. How much less helpful could it be? I have had little luck trying to find a comparable regulator or voltage reference.
Old 4th August 2006, 03:35 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi macboy,
Oh man. It's not even a real part. Somewhere there is an original that this part is supposed to be. Don't bring anything in for service at that shop ........
It looks like an LM317 type regulator. Have a peek at the datasheet for those.
-Chris
Zener regulator with "integrated" pre-regulator 00940 Power Supplies 17 22nd July 2008 05:11 PM
Lithos regulator - A new super regulator? peranders Parts 7 8th May 2008 02:01 PM
SCR pre-regulator jesper Solid State 7 8th September 2003 07:53 PM
Regulator for CD jevta Digital Source 2 24th August 2003 08:28 AM
Page generated in 0.07446 seconds (70.07% PHP - 29.93% MySQL) with 10 queries
