diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   lead-free solder: shiny when liquid but suddenly it turned dull when it solidified (http://www.diyaudio.com/forums/parts/84216-lead-free-solder-shiny-when-liquid-but-suddenly-turned-dull-when-solidified.html)
jarthel 4th August 2006 01:18 PM
should I be worried? the station was at 300 degrees celsius.
thanks for the replies
rabbitz 4th August 2006 03:02 PM
What you see is what you get with lead free.
Personally, I'm stocking up on leaded solder before it disappears.
jneutron 4th August 2006 07:30 PM
Re: lead-free solder: shiny when liquid but suddenly it turned dull when it solidified
No, there is no worry. What you need to look for is the wetting of the solder to the materials. A good joint will have the same geometry regardless of the alloy type.
The only thing you need worry about is the higher temperatures required for the solder, as insulation and parts are temp sensitive.
As the solder ages, it'll get worse. Why not get the new stuff and learn how to use it?
A process hint:
When using this higher temp stuff, I use a liquid R type flux, squirt a little into the joint, then use the iron to melt the solder, push the solder inbetween the tip and the part..Let the molten solder heat the parts up, instead of the iron to part contact. If you work this right, you can keep the parts from getting too hot while the reflow is taking place. It's like heating chocolate by using a pan within a pan, water being the transfer fluid..the inner pan will never go over 100C.
Takes a little practice, but the guys here larned it purty quick, and so far, only one bad joint.
Cheers, John
pinkmouse 5th August 2006 06:52 PM
:cop:
Off topic stuff removed, we don't really need this argument to start up again...
Copyright 1999-2017 diyAudio
