Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 31st July 2006, 12:04 AM   #1
jarthel is offline jarthel  Australia
Default IEC AC Filter
can someone please tell me if the ground output of this filter is derived ground and the AC ground is left hanging?
Here's the schmetic: http://www.cor.com/Series/IEC/EEAEEB...-Schematic.gif
If it is derived ground, does that mean I cannot connect the metal chassis to this derived ground. I've always grounded the metal chassis to AC ground for safety.
Thank you.
ps. I haven't bought the filter yet.
Old 31st July 2006, 12:14 AM   #2
poobah is offline poobah  United States
poobah's Avatar
That ground is connected straight through. The identical symbols imply an identical node (wire). The ground is not "derived".
You will also find those to be a nice device and very cost effective.
Old 31st July 2006, 12:24 AM   #3
thanks for the help
Old 31st July 2006, 01:19 AM   #4
poobah's Avatar
Keep in mind, I've heard plenty of comments around here that those things will "constrict" your sound... pure B.S. Make sure you have an adequate current rating in the device you choose.
The rectifiers in your PSU will make some RF (hash) of their own of course, but YOU control that. The power line is a different story.
Old 31st July 2006, 01:15 PM   #5
re post1:- what is that resistor for?
To discharge the three tiny capacitors?
You can buy chassis mount version that range from about 1A to 6A.
You can also build your own.
But, since you are working with mains voltage you must know what you are doing and how to protect users and maintenance technicians.
regards Andrew T.
Old 31st July 2006, 01:25 PM   #6
SY's Avatar
WAG here, but I'd wager that it's there in case the line (source) circuit is disconnected.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 4th August 2006, 03:48 PM   #7
Brian Beck's Avatar
Default Resistor?
Yes, it would bleed stored charge off the caps for safety’s sake, in case connections to the load and line are both opened. My guess is that the shunt resistor also figures into the damping of the resonance(s) created by the shunt Cs and series Ls. Neither the line nor the load will have known or controlled impedances and can offer no guarantee of damping of resonances by themselves. In particular, the line side impedance could be dominated by high series inductive reactance, thereby contributing only reactance to the resonant mix. The resistor might then set a worst-case maximum value of Q.
Brian
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 9th February 2008 11:38 PM
Can Zaphs notch filter be used without the BSC filter? GuyPanico Full Range 0 21st July 2007 01:27 AM
Just one big filter cap or more smaller filter caps ... beppe61 Power Supplies 2 18th July 2006 05:46 PM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 01:12 PM
chassis-mounted filter or IEC plug filter jarthel Solid State 7 11th March 2002 10:17 AM
Page generated in 0.08851 seconds (77.36% PHP - 22.64% MySQL) with 10 queries
