| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
If you connect a transformer to the mains, but do not connect the secondries to anything, will the transformer draw any power?
If the transformer is unloaded, will the secondary voltages be exactly as rated for the transformer? And then the more the current you draw, the more the voltage will drop? Or does the voltage only drop after you exceed the VA rating? Would you say 25v capacitors are ok for smoothing DC in an unregulated PSU when using transformer with 15v secondries? (15 * 1.414 = 21.2) Cheers. |
#2 |
diyAudio Moderator Emeritus
If a transformer is connected to the mains but is unloaded, it will still dissipate some power due to the resistive losses in the primary.
If the transformer is unloaded the secondary voltages will not be exactly as rated. Usually manufacturers rate the secondary voltage at a certain current. The less current you draw the higher the voltage will be and vice versa. There is also a % regulation spec which tells you how much the secondary voltage will deviate when unloaded. Higher VA rated transformers will have tighter regulation and lower VA rated ones will have more variation in their output voltage depending on the current. 25VDC rated caps should be ok to use with your 15VAC transformer. I would get some caps with a 35VDC rating if you don't already have the 25V ones.
Brian |
#3 |
BWXR: " ... 25VDC rated caps should be ok to use with your 15VAC transformer. I would get some caps with a 35VDC rating if you don't already have the 25V ones. ..."
... Careful here: A transformer output voltage rated at +/- 15 Volts AC is capable of easily resulting in +/- 25 Volts DC ... so if you are using 25 VDC rated capacitors, you are riding right on top of the absolute maximum voltage rating that the manufacturer suggests = which could also easily be +/- 10% of the "real" maximums = or as low as a "true" rating of ~< 22 Volts DC = Oops = zzzzztttt ... smoke ... FYI: Voltage AC through a common, full wave, bridge diode rectifier produces 1.707 Times the Voltage AC across the well regulated DC rails = the peak voltage ... that's what they mean by RMS = Root Mean Square = the peak voltage of the AC sign wave representated by the AC voltage .... and it can be mean and nasty. I always use capacitor ratings at least 1.5 times the expected DC voltage ... 'cause some of them component manufacturers lie about their ratings, no polliter way to put it.
#4 | ||
Brian |
#5 |
" ... Easily capable of 25VDC? Not easily, but it could happen ..."
Well, every time I use +/- 15 VAC (center tapped or not) and connect that to any diode bridge and parallel filter capacitor, I get a reliable volt meter reading of 25.605 Volts DC ... every time! ... unless there is something wrong with my meter. Even if you onle have a half wave rectifier (two diodes) the results above will be the same, every time .... or else Maxwell was wrong ...
#6 |
" ... I always try to use caps rated at twice the expected voltage but that's not always economical. ..."
Yes, I suppose so ... In the case of smaller caps, I double the expected DC voltage for the cap rating as well. There are several inexpensive ways to "secure" very large capacitors from voltage spikes, or "near death" experiences ... But I will stick to what I said: 1.5 X expected DC voltage as a minimum reliable, workable, safe spec.
#7 | |
I have a 120V 120VA Plitron toroidal with 15VAC secondaries @ 4A and 11% regulation. With a full wave bridge rectifier, a 22,000uF cap, and a bleeder resistor I have seen up to 24VDC unloaded with 121VAC line voltage. If your transformer has worse regulation it's possible to see higher like you're seeing. An easy solution is to use a lower value bleeder resistor to draw more current and pull the voltage down a bit, or you could get a better transformer
Brian |
#8 | |
Enjoy good sound
Careful here... Correct would be VPeak=VRMS*Sqrt2 sqrt2=1.414.... So Vpeak=VRMS*1,414.... If you want to go back: VRMS=VPeak/(1/sqrt2) 1/sqrt2 = 0,707......So VRMS=Vpeak/0,707....
/ Anders |
#9 |
" ... I have seen up to 24V unloaded with 121VAC line voltage. ..."
You are probably quite correct. I used a multiplier of 1.707 instead of the (correct) multiplier of 1.414 .... make 24 VDC closer the the upper limit on the rails. Looks like You are right on this one ... and so is Maxwell. But my statement still stands = 1.5 times expected (peak or DC) voltage for a well behaved capacitor = no fried weenies ...
#10 | |
Enjoy good sound
Probably you mean that unloaded tranny put out some more voltage. Value can found in transformer specs so you can make more precise calculations. Regarding voltage, ceep in mind that line voltage can vary approx +/-10% and so on both primary and secondary.
/ Anders |
| Need a little transformer Theory help.. | Hiwatt25 | Chip Amps | 12 | 4th February 2008 05:08 PM |
| Equations,Calculations & Theory of FERRITE TRANSFORMER design | dhanukak | Power Supplies | 4 | 17th September 2007 02:41 AM |
| Two questions of speaker theory | BAM | Multi-Way | 3 | 6th January 2004 03:35 PM |
| Help with transformer theory and practice | Ulas | Digital Source | 4 | 12th July 2003 03:35 AM |
| Page generated in 0.13052 seconds (82.04% PHP - 17.96% MySQL) with 10 queries |
