Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th July 2006, 06:20 PM   #1
dube is offline dube  United States
Default capacitor help needed
well i have blown a capacitor on my crossover and iam in need of a replacement any sujestion ?? it is a bennic. bi-polar.47 mfd.100 wv. and since i have my speakers apart iwas thinking about some more damping material or any diy upgrade
THANKS GARY
Old 24th July 2006, 08:09 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Gary,
If the value is not too critical you can make your own bipolar by using two 100µF caps.
Connect them in series but tie both negative legs together and use both positive legs as the terminals.
/Hugo
Old 25th July 2006, 09:29 AM   #3
is it 0.47mfd or 47mfd or 0.47uF or 47uF?
If it is only 0.47 then a 100V plastic film can be used. This might change the sound for the better or worse.
If 47uF then 100V bi-polar electrolytics are available. My Rapid catalogue shows them at £0.19 each. You could use a motor start, plastic film cap here if you want the highest spec but they are very bulky and expensive.
regards Andrew T.
Old 25th July 2006, 02:25 PM   #4
it is a 47 mfd
just looking for a good replacment
thanks gary
Old 25th July 2006, 02:41 PM   #5
is this another US manufacturer mis-using mfd when they mean micro farad (uF)
47uF 100V bipolar are readily available. It cannot be 47,000uF 100V or could it?
Panasonic are reputedly very good but many others are out there.
regards Andrew T.
Old 25th July 2006, 02:41 PM   #6
hughmon is offline hughmon  United States
These guys carry Bennics, though the closest value they stock to 47uF seems to be 50uF.
http://www.madisound.com/cgi-bin/ind...eywords=Bennic
Old 25th July 2006, 06:08 PM   #7
50 uF is close enough. Many caps are rated ±10% and then listed for the top end of that range. In other words, a 50 uF cap could "really" be a 47 or even 45 uF.
As I recall the original poster listed this cap as being in the tweeter circuit. 47 uF is a very large value for that location in a schematic. I think that 4.7 uF would be closer to what is needed.
Or, is this a 3-way speaker and the cap is in the midrange driver circuit.?
Also, how do you know this cap needs to be replaced? Did you test it?
Old 26th July 2006, 09:33 AM   #8
Netlist's Avatar
The can looks very empty on the picture.
/Hugo
Old 26th July 2006, 10:05 AM   #9
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
That's not a dead capacitor.
It's a Norwegian Blue cap and it's resting !
Old 26th July 2006, 10:21 AM   #10
pinkmouse's Avatar
Nah mate, it's pining for the fjords...
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Carver M-1.5t power supply capacitor boards needed wrthissell Solid State 3 13th October 2011 02:53 AM
Capacitor advice needed for AVA PAS rebuild amichalik Tubes / Valves 1 25th June 2006 10:14 PM
Re: Recommendation on capacitor value needed Sunsun22 Solid State 14 2nd July 2005 11:43 AM
Ultra tiny capacitor needed kevin gilmore Solid State 1 3rd June 2004 12:37 PM
Page generated in 0.12994 seconds (74.35% PHP - 25.65% MySQL) with 11 queries
