| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
what I’m talking about is electrical watts vs mechanical watts.
e.g. I have a brushless motor and its rated at 1200watts now would that be the electrical power it draws volts x amps? Or output mechanical torque? this is the 1930/8 turn motor: http://www.finedesignrc.com/lehnerspecs.htm It says "Power(Watts) @ Amps" so they tested the 1930 on 40v? |
#2 |
The max power the motor takes up is when is loaded at max mechanically, just before it stalls. But there are also mechanical losses. If the motor has an efficiency (and I'll just pluck a number out of thin air now) of 75%, the mechanical output at that 1200W electrical input is 900W, just over one HP (which IIRC is 750W or thereabouts).
Jan Didden
/Another new issue: Linear Audio Volume 3! |
#3 | ||
diyAudio Moderator Emeritus
C'mon Jan, you were way off Quote:
The torque of the motor is dependent upon the thickness of the windings and the number of windings used (ok and the magnet strength, and geometry, etc...). The thicker the wire and less number of turns in the winding the more torque the motor will develop. Seeing that the windings are just copper wire their impedance is very low and doesn't require a whole lot of voltage for massive amounts of current to flow. That's why the lower turn motors have higher rpm/V ratings than the higher turn motors. I've been into electric RC cars and helis for a while now and this brushless stuff is way better than the brushed motors of the past! I love 10 minute flight times with a 7 cell NimH pack in my heli
Brian |
#4 | |
... but closer than most goverment work..! Jan Didden
#5 |
to get 1200W @ 30A, they must have tested at 40V. That's some battery pack 40V & 30A. The spec sheet says rpm/volt. I think they are saying what the rpm is when used at the specified voltage (mis-use of terms?). The problem is they don't actually spell out the voltage, anywhere. Most motors operate at maximum efficiency when driven at about half their no load maximum RPM. Does this rule apply to brushless?
regards Andrew T. |
#6 | |||
just looked up Wikipedia for confirmation. Quote:
But there are two otherdefinitions in common use. Quote:
regards Andrew T. |
#7 |
It is rpm/volts meaning if the kv rating is 5000kv if you put 2 volts on the brushless motor you x it by 2 = 10000rpm 6v on the motor = 30000rpm I have not seen yet a maximum volt or rpm rating on a brushless motor there will be a limit so what is it?
Btw the world record r/c boat used a 38.4v pack on a lmt 2250 3000watt @ about 41,318 rpm up to 100amps |
#8 |
janneman: " ... The max power the motor takes up is when is loaded at max mechanically, just before it stalls. ..."
Well, I would have said just before the motor begins to slow down toward a stall ... or if motor RPM is just below its best power point = increasing current draw and thermal runaway ... Interesting conversion tool is on the newer Apple Mac Dashboard ... "Unit Converter" ... converting horsepower to watts = ~ 1 HP to 746 Watts (as noted by BWRX above). The Wikipedia conversions carry out further, decimal point wise, but are a litle combersome to find and use. The original British "horse power" rating was the ability of a healthy horse to pull and lift 550 pound weight one foot in one second = no mean feet / feat. The more modern (and less satisfactory Society of Automotive Engineers (SAE) have (variably) compared "horsepower" to all manner of standards, eventually landing on fluid power ~= 1 HP = ~ 1 gallon per minute (GPM) @ 1460 pounds per square inch (PSI) ... the French equivelient (meteric) being seldom used for anything except classroom excercises and term papers ... AndrewT: " ... Most motors operate at maximum efficiency when driven at about half their no load maximum RPM. Does this rule apply to brushless? ..." More like 66% of maximum RPM, brushless or not ... |
| FE 166/ 167/ 206/ 207 - 40 watts? | otto88 | Full Range | 10 | 4th February 2010 10:53 AM |
| Decibel Watts VS Watts ? | fivestring | Solid State | 11 | 1st April 2009 01:08 PM |
| Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 06:25 AM |
| SPL and Watts | Matttcattt | Everything Else | 6 | 14th March 2004 10:00 PM |
| Need 2 watts | Vivek | Everything Else | 4 | 17th July 2003 08:29 AM |
| Page generated in 0.12102 seconds (82.03% PHP - 17.97% MySQL) with 10 queries |
