Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 20th July 2006, 07:05 PM   #1
cpemma is offline cpemma  United Kingdom
Default Best pot cleaner (available in the UK)
Search gives me some American brands I've never seen over here, so UK only please.
What's best for killing noise when the knob's moved? Choices seem to be,
  • Maplin Electrical Solvent Cleaner - got some, not impressed. No idea what solvent it is.
  • Servisol IPA 170
  • Electrolube 99.7% IPA (a more expensive IPA)
  • Servisol Aero Klene 50
  • Any other to recommend?
Old 20th July 2006, 07:11 PM   #2
frank1 is offline frank1  United Kingdom
Sorry but a new pot is the best solution.
Cleaners may work in the short term but if a pot is noisy, it is likely that the track is worn out and/or the wiper spring tension has gone.
Frank
Old 20th July 2006, 07:40 PM   #3
It's a dual-concentric (no separate balance pot) and I can't find a replacement.
Old 20th July 2006, 10:16 PM   #4
dnsey is offline dnsey  United Kingdom
If you can find a couple of new single gang pots of the same type, it's usually possible to swap the tracks.
Old 21st July 2006, 04:23 PM   #5
Default Re: Best pot cleaner (available in the UK)
  • Servisol IPA 170
I always use 'Servisol Super 40', it's a WD40 clone - works far better than any switch-cleaners I've used. Been using it probably for 25 years professionally?, never had a problem with it, the lubrication properties of it really seem to help with pots.
Nigel Goodwin
best CD/DVD/CD-ROM cleaner jives11 Everything Else 3 6th June 2007 05:52 AM
contact cleaner odysseybmx414 Parts 14 3rd January 2007 04:21 PM
DIY Cleaner $$$ ? LHMAudio Analogue Source 21 12th June 2006 03:39 PM
Found By The Cleaner mrfeedback Everything Else 2 23rd January 2003 06:22 AM
Page generated in 0.07400 seconds (74.33% PHP - 25.67% MySQL) with 10 queries
