| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Proud Union Member
Hello all, I would like to use one of those cheap single board lcd meters to measure DC current. The apparent problem is that the meter has a 200mV input. The current shunt is 50mV. Is there a way to scale the meter down? Thanks!
#2 |
Hi imix500,
I think 200 mV FS is the basic sensitivity for those chips. You need to build a DC amp. DC drift may be a problem unless you are careful with your integrating cap type and op amp. Leakage paths need attention too. -Chris |
#3 |
Proud Union Member
The dc amp seems correct, I wish I could find a 200mV shunt.
Hmm, I found an article that suggests that because the a/d convertor needs no current for measurement, full scale input isn't needed. A sample schematic shows a 50mV shunt resistor feeding a 200mV meter. Here is the page: http://sound.westhost.com/articles/meters.htm Does this sound right? |
#4 |
What is the maximum level of DC current you wish to measure?
There are several sources for many types of shunts... a shunt is merely a precise resistor with 4 contacts. For maximum accuracy, you should use the full scale that is available to you. Unless, of course, this gives you some really weird conversion factor for your displayed value. |
#5 |
Hi imix500,
All you really need is a resistance that scales your FS current to a convenient range with the meter if you are willing to use a different shunt. You can use less than the full scale keeping in mind that you may possible lose some resolution - or not. If you want 5A FS, your 50 mV shunt is correct the way it is. A four terminal resistor is the best, make your sense traces come off so you don't share any part of the trace with the load current. To start, what current do you want to measure? -Chris |
#6 |
Ha ha... beat ya bud...
#7 |
Hey quicks draw!
I was thinking pie as a correction factor, you ? |
#8 |
I actually like e better than pi... unless it is warm raspberry with good vanilla ice cream.
#9 |
I was trying to keep it easy. 1 to the power of infinity takes too long to figure out.
#10 |
Proud Union Member
You guys crack me up. I was thinking a nice round number like... 50A. it's for a water cooled test rig for power supplies.
| how to make this esr meter work with 250uA Panel meter | dytln_02 | Everything Else | 2 | 27th January 2007 11:13 PM |
| Making a milliAmp meter, become a Volt meter | redrabbit | Power Supplies | 11 | 26th May 2006 08:51 PM |
| Measuring current with an LCD meter | Matttcattt | Parts | 10 | 12th May 2004 01:13 AM |
| Making LED voltmeter | Dima | Equipment & Tools | 5 | 3rd August 2002 02:11 PM |
| Making series Vreg to sink current | KasperM | Solid State | 1 | 30th November 2001 07:30 PM |
| Page generated in 0.09906 seconds (76.92% PHP - 23.08% MySQL) with 11 queries |
