Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th July 2006, 06:55 PM   #41
anatech is offline anatech  Canada
anatech's Avatar
Hi imix500,
What value load resistors are you using? Contact resistance will be variable, so it looks like you have to use hardware and switch them yourself.
You could use relays and measure each leg individually to calculate the total load, that's the only other way I can think of. Use Mercury wetted if you can find them.
-Chris
Old 14th July 2006, 07:54 PM   #42
imix500 is offline imix500  United States
Proud Union Member
imix500's Avatar
Hi anatech, the resistors are 6.6 ohms 600W. Kind of a strange value but I couldn't pass them up for the price. The relays I have are 40A automotive type.
Considering the max current across any one of them with a max input voltage of 100V would be 15A they should do fine. The only thing I'm wondering about with using them at that voltage is arcing across the contacts when I take them out of the circuit.
I might just pick up some ice cube types off ebay.
Why mercury wetted?
Old 14th July 2006, 08:10 PM   #43
anatech's Avatar
Hi imix500,
Why mercury wetted?
1. They are environmentally unfriendly if you open them.
2. The mercury prevents the contacts from arcing. The arc takes place on the mercury. Much longer contact life.
I would not count on the contact resistance with any switch or relay at those currents unless you are using contactors. Even then .... Breaking 15 ADC at 100 VDC is not trivial! Switching AC is much easier as the arc self extinguishes 120 times a second. Some of the other members are well versed in this application. I know enough to say I don't know enough to advise you fully.
My advise: Turn the supply off to change the load, do so by connecting with a screw into a heavy terminal block. Not even the familiar Jones barrier strips are rated for your full current. Use a lockout switch so a co-worker does not energize you!
Is there an industrial electrician in the house? An electroplating guy would be ideal I think.
-Chris
Old 14th July 2006, 08:20 PM   #44
Proud Union Member
imix500's Avatar
Yeah, I may have to look around for relays. If I can find them surplus, dc solid state relays would be cool.
Powering down before changing the load is probably what will happen most of the time, but I'd hate to burn a relay if the unexpected happens.
The barrier blocks I have are the ones found on the back of a Crown MA5000. I don't know the exact rating, but they are beefy, waiting to hear back from crown on that. It will also have the new NLT4 connector, for load testing some amps at work.
Old 14th July 2006, 09:44 PM   #45
poobah is offline poobah  United States
poobah's Avatar
Look here
Not that spendy either... I have used thousands of these guys.
Old 14th July 2006, 09:53 PM   #46
anatech's Avatar
Perfect for current events poobah!
(I guess I'll be flayed for that one )
-Chris
Old 14th July 2006, 10:07 PM   #47
Proud Union Member
imix500's Avatar
Geeze, puns-a-plenty here at diyaudio. I just bought some 35A mercury contactors, they should do the trick.
Old 14th July 2006, 10:12 PM   #48
anatech's Avatar
Hi imix500,
Occasionally check the voltage drop across the contacts as you raise the current. You have added another variable to the load.
Otherwise, I don't think you could reasonably do any better.
-Chris
how to make this esr meter work with 250uA Panel meter dytln_02 Everything Else 2 27th January 2007 10:13 PM
Making a milliAmp meter, become a Volt meter redrabbit Power Supplies 11 26th May 2006 07:51 PM
Measuring current with an LCD meter Matttcattt Parts 10 12th May 2004 12:13 AM
Making LED voltmeter Dima Equipment & Tools 5 3rd August 2002 01:11 PM
Making series Vreg to sink current KasperM Solid State 1 30th November 2001 06:30 PM
Page generated in 0.09296 seconds (81.02% PHP - 18.98% MySQL) with 11 queries
