Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th July 2006, 10:05 AM   #1
Default Stepped attenuator
Hi All,
Maybe this is just nothing, but trying to build a stepped attenuator using resistors I tried a technique employed in the UK to attenuate audio leads.
Connecting resistors to signal and ground through the 6-way switch I have, there's no resistors directly in the path. I understand the quality of resistors employed in this way should be very high-I just used some standard 1% 0.6w jobs I had. All values I built in were too high apart from 4.7 ohm. I think it could be built as a 6 way switch with values from 2-10 ohm and cover all I need.
Any thoughts?
diy stepped attenuator under 10$ kaushik Parts 23 12th January 2012 11:37 AM
stepped attenuator pop Ted205 Chip Amps 17 21st July 2008 03:10 PM
Stepped attenuator Bas Horneman Tubes / Valves 24 16th June 2004 08:18 AM
Stepped Attenuator officeboy Parts 3 6th May 2004 04:32 PM
Page generated in 0.07018 seconds (62.65% PHP - 37.35% MySQL) with 11 queries
