Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th December 2002, 02:04 PM   #1
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default 0,0047uF = 47pF?
Sorry for asking such a trivial question...but
is 0,0047uF equal to 47pF???
Old 4th December 2002, 02:07 PM   #2
jean-paul's Avatar
No, it's 4.7 nF. Which is the same as 4700 pF.
On your calculator:
uF is 10 with exponent -6.
nF is 10 with exponent -9
and pF is 10 with exponent -12.
Note that the international way to express these values is by using a dot instead of a comma. In Europe we write down 4,7 which confuses others. We write down 10.000 for ten thousand whilst the Americans write down 10,000 for the same thing.( If I'm correct ).
It's only audio
Old 4th December 2002, 02:07 PM   #3
Send a message via AIM to Austin
Default nope
.0047uF would be 4.7nF and 4700pF
uF=10^-6
nF=10^-9
pF=10^-12
Austin
Old 4th December 2002, 02:10 PM   #4
47pf would thus be 0,0000047uF?
Thanks for the replies!
Old 4th December 2002, 02:13 PM   #5
UrSv is offline UrSv  Sweden
UrSv's Avatar
No, it would be 0,000047uF.
/UrSv
Old 4th December 2002, 02:17 PM   #6
jean-paul's Avatar
Bas, if you use the 0,0000xxx way of noting values errors creep in easily.
Try the exponent way of expressing these values on your calculator and your cross over filters will require much smaller caps ( or bigger ) than you calculated before
It's only audio
Old 4th December 2002, 02:23 PM   #7
chris ma's Avatar
Please check the numbers here
Old 4th December 2002, 05:25 PM   #8
sam9 is offline sam9  United States
sam9's Avatar
Default The Cosmic Question is :
Who decided on making a Farad so big, anyway? Ocassionally, ones sees a 1F cap used for an autosound system (the one that drives you nuts sitting at a stop light, no doubt). Otherwise, it seems of no use except to microwave a cow or fire up 'ole sparky.
Old 4th December 2002, 05:29 PM   #9
chris ma's Avatar
Ah...Far..rad....I remember there used to be a guy around called Faraday, might have been a DIYer too....
Chris
Old 4th December 2002, 05:33 PM   #10
jan.didden's Avatar
Default Re: The Cosmic Question is :
I think they defined it as a cap that gets charged 1 volt by 1 Amp for 1 Sec. They really couldn't predict we would be working with uamps 100 years later, could they?
Jan Didden
Find Rhoos compatible 47Pf??? Progg70 Parts 2 31st January 2009 01:58 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
