| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#61 | |
Also try printing onto paper and photo-copying using a high-quality machine at a copy shop, if your laser printer doesn't give good results. Different printers and copiers will produce different results. Toner thickness, line sharpness, and even-coverage of large areas all vary widely on different machines. If you have access to different machines at work or at school, try several. If the result after peeling doesn't look good enough, clean the toner off with some kind of solvent and try again. As with the paper method, you will need to experiment with iron temperature, time, and pressure, to get good bonding without bleeding. And different brands of transparency sheets probably bond with the toner differently too. It helps to carefully examine and touch-up the traces with a sharpie marker after peeling, to fix any cracks, gaps, or thin spots. |
#62 | |
That won't hurt the iron. you should use an old cotton towel, though, since it is likely to get a bit brownish. |
#63 | |
#64 |
Hi All
Fascinating thread. Im interested in getting the old 70's style darkish brown PCB material to mend some vintage guitar pedals-all the board nowadays is a light tan colour ora light green! Any sources for this please |
#65 |
valvusmusicus, I have seen old fr4 from Rayhteon (supposedly) on ebay. from what seller I don't recall. but I have also wanted to get my hands on older, brown material. there used to be a place herein Ottawa, that sold really old fr4 in bare copper boards. They were made by a company called... oh, I can't remember, it started with an a. I'll ask a friend. But your best bet is ebay or all those wonderful electronics surplus stores there are in the USA. (there ain't none left in Canada, cause there isn't enough population). Maybe in "Torana"...
Trans-directional-servo-logamp non-zerocrossing autogain compressing thingamajig |
#66 |
I am glad my thread has generated so many comments, and lasted 6 years!
#67 |
The "old" brown boards were usually a phenolic paper sandwich, not fiberglas FR4
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals! |
#68 |
there are some "brown" boards that aren't phenolic. I don't think the military uses phenolic in high reliability applications.
Wierd military computer boards |
#69 |
Circuit boards are made in a large variety of colours and materials, particularly for pro or high-rel use. Coating laquers and solder masks often camouflage the colour of the base material. Consumer grade boards were still mostly paper-phenolic up until the late 70s or so.
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals! Last edited by AuroraB; 9th March 2012 at 07:06 PM. |
#70 |
Most base material is pretty much the same colour, the type and colour of the final coating determine the finished products colour more than anything else.
The paper-phenolic (CEM) were usualy a lightish cream colour when new, often deepening in colour with age. These were only used for simple designs. Where more layers were required and SMD FR4 based laminates are generaly used (with more exotic materials used for very high GHz applications).Felx and flex rigid boards can have a brown apearance due to the polymer used for the flex laminate. Also in the past a variety of coatings where used to protect circuitry and boards, again having a variety of colours from quite clear to a dirty brown. FR4 (the most widely used laminate base) is just flame retardent GR5 based fibre glass. CEM and paper based are now only 2% of world production of PCB's now, not often used. |
| What's the best method to rip CD to HDD? | kop89 | Digital Line Level | 124 | 24th June 2009 04:56 AM |
| FC amp, there is any method to reduce H3? | roender | Solid State | 3 | 14th June 2007 04:23 PM |
| Anyone tried this method for OTL? | jerluwoo | Tubes / Valves | 3 | 23rd November 2006 11:46 AM |
| best grounding method | Leolabs | Solid State | 0 | 20th October 2006 01:21 AM |
| Auspurger Method for TL | sianturi | Multi-Way | 10 | 26th February 2003 11:29 PM |
| Page generated in 0.11707 seconds (80.69% PHP - 19.31% MySQL) with 11 queries |
