Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th July 2006, 01:36 PM   #1
sdoom is offline sdoom  Germany
Default CT-W300 Tape womt record
hi @ all.
I got a tape (Pioneer CT-W300) that wont record at all. This is a dual - tape. Tape A only can playback, Tape B can playback and record.
Both tapes play back correctly.
If I feed an input signal to the inputs both level meters work correctly , level can be adjusted with the record level shifter, too. But when finished recording, there is still the old music on the tape as it was before . Sometimes it is audible, that the recording is there in the background, but very silent and not all the time.
I have a good understanding of reparing amplifiers but I only have little knowledge about tapes. I checked the TAPE B tone-heads (fully metal type) with an ohmmeter and both coils read 220 Ohms, compared eith TAPE A I have the same readings there.
There is an additional black plastic type head in TAPE B. I assume that is a "delete head" ? It reads only 1,4 Ohms.
I tried to measure the voltage across this plastic head, and it is always 0.00V, regardless if in playback or recording mode. Is this section faulty ?
Am I right if I say, the delete head deletes the tape in record-mode and the fully metal head is used for both playback and recording ?
Thx,
Stephan
Old 13th July 2006, 05:45 PM   #2
No one around who can tell me how a tape recording works ?
My DIY record cleaner. mattjk Analogue Source 103 8th November 2009 07:20 PM
Should I Wash a N.O.S. Record? DaveThreshold Analogue Source 1 5th February 2009 11:51 AM
tape wont record sdoom Everything Else 13 21st July 2006 06:07 AM
A new record? peranders The Lounge 1 8th May 2006 08:56 PM
TEAC x-2000r record mode stuck. Record light flashes but won't play. Any ideas? mistered05 Analogue Source 1 30th June 2005 01:51 PM
Page generated in 0.08380 seconds (70.64% PHP - 29.36% MySQL) with 10 queries
