| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I've been using an amplifier based on LM3875. One problem with it is that it makes a very annoying "POP' noise whenever I turn the lights on/off. I guess this is due to a so-called "spike voltage" from the AC mains. I've checked some textbooks on basic electronics and found that TVS (Transient Voltage Suppressor) could be used to kill this kind of spikes. Now, I'm wondering if any of the DIYers here tried this. If so, please let me know the result. This POP sound is killing me. Thanks.
JAZZ2250 |
#2 |
For AC transients I am not a fan of TVS Diodes (seen to many of them blown). I would use something like the Panasonic ZNR type (check DigiKey) or a MOV type.
Ultimate protection system would be: Line IN a gas discharge tube a low value resistor ZNR or Mov line out (for DC, best bet is TVS diode) Note: TVS diodes fail to a short ckt - not nice on AC line! ZNR & MOV fail open ckt. |
#3 |
What you really need is a snubber across the light switch contacts. A 47r 1w resistor and a 1uF 250 VAC X cap *ac rated* in series should help a lot. Something similar across the mains input of your amp would be good too. *Important* use an X type AC rated cap that has UL, CSA and other safety agency approvals. Put both the cap and resistor inside a small metal box just to be 10000% sure of fire safety.
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#4 |
Question?
Is the pop really due to mains voltage, or due to RF spike and amp leads acting as antenna? -Dan |
#5 |
Thanks, crown300.
I checked digikey for Panasonic ZNR (type D). I was able to understand what MAV (Maximum Allowable Voltage) means. As I measured, the AC mains is 120V, and hence MAV has to be higher than 120V. Right? Will 130 or 140V do? Then, what should I choose for Vc (Varistor Voltage) and Max. Clamp Voltage @ Test Current? Sorry for a dumb question and thanks for your help. BTW, I've lived in Raleigh, which is close from Pittsboro, for one and a half year. It was a pretty nice place to live. :-) Thanks, Circlotron. It seems opening the switch box of the light will be a little bit difficult for me because I'm living in an apartment. :-) But, thanks for your valuable advice. I'll file your recommendation for my future reference. JAZZ2250 |
#6 | |
Darrell Harmon
http://gemini.tntech.edu/~dlh5678 |
#7 |
So, 120VAC at mains is RMS value and MAV is not? Confusing. 120VAC RMS = 120*1.414 = 170V, and Vpp = 2*170V = 340V. Shouldn't I choose MAV = 350V or higher? Again, confusing.
#8 | |
-Dan |
#9 |
OK, then, another dumb question. Am I going to connect two ZNRs (wih MAV rated at 200V) btwn "neutral and hot" and "neutral and ground"? Or, one rated at higher than 340V btwn ground and hot (nothing connected to neutral)?
#10 |
I believe the traditional setup is to use 330V MOVs between:
Hot and Neutral Hot and Ground Neutral and Ground or just between Hot and Neutral Check this out though since I am not an expert. Darrell Harmon
| Noise canceler/suppressor | Redfoxfur | Instruments and Amps | 12 | 3rd June 2008 03:11 AM |
| distortion suppressor idea | keantoken | Solid State | 15 | 17th September 2006 11:36 PM |
| Noise Suppressor, just a cap? | silentblackhat | Parts | 10 | 13th June 2006 05:19 AM |
| *CC suppressor cap query | lazyfly | Chip Amps | 2 | 9th March 2005 07:23 PM |
| DIY surge suppressor? | cowanrg | Everything Else | 2 | 23rd June 2003 01:11 AM |
| Page generated in 0.11900 seconds (82.77% PHP - 17.23% MySQL) with 11 queries |
