Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th July 2006, 11:32 PM   #1
Default Use standard 317 or 317L?
I plan to use 317/337 for an application with a load current between 10 -- 20 mA. My initial guess was that for such small loads, the 317L would probably be better than the higher-current versions like 317T. However, comparing the datasheets (brand ON in this case) I find almost no important difference between them. Load and line regulation are the same. Noise is the same. They even have the same minimum load current. The only striking difference is that ripple rejection vs. frequency seems better for the L version, being almost flat up to around 10 kHz, and thus better. On the other hand, it is not clear if that diagram assumes the use of Cadj or not, which I might not be able to use in my application. Also the L version will of course get a bit hotter, although I won't go near the max Pd spec, which will influence some parameters.
It seems the L version is the better choice for ripple rejection and lower price, but are ther are factors I am missing? Of course different brands will behave differently too.
Yes, I guess I eventually will have to measure them and compare anyway, but I would be interested in opinions and experiences.
Old 6th July 2006, 04:29 PM   #2
testlab is offline testlab  United States
testlab's Avatar
For those loads, the L version should be fine. Just make sure that you have all of your capacitors as shown in the application data. Do however, resist putting the reverse diode across the regulator. This has been known to rectify RF and cause errors.
It's not whether you win or lose, it's how you lay the blame.
Old 6th July 2006, 06:35 PM   #3
Maybe I was unclear in my question. I know the load itself will be no problem. The question was rather whether the L version might perhaps perform better than, for instance, the T version for such small loads, or if it is maybe the other way around, that the T version performs better even att small loads?
Thanks for the hint about he diode. I am not sure yet if I could safely omit it, but I'll consider it.
Old 6th July 2006, 07:12 PM   #4
jackinnj's Avatar
both the L and T versions like to be loaded.
as for the rectification effects -- i have not experienced this with an NPN regulator --
Old 6th July 2006, 07:13 PM   #5
I would bet a sizeable number of centimes that they are essentially the same chip inside the package.
Old 6th July 2006, 07:30 PM   #6
Meaning the L version would perform better for loads within its capability range? That was my initial assumption. I will probably already have to add dummy load resistors just to be safely above the 10 mA minimum current.
Just different packages and different current limits? Possibly, but the representative schematics of the two are quite different, and they at least seem to differ considerably in ripple performance.
Old 6th July 2006, 07:59 PM   #7
jackinnj's Avatar
where do you get centimes anymore? last time I got a centime in France it was 1967. still using ha'pennies, tuppence, crowns, and shillings over there?
back to the LM317L (or 317M) you have to take into account the difference between Vin and Vout, multiplied by the various currents, elsewise the device seeks to protect itself. the 317M's will do 1/2 amp and they are easy to heatsink as they are D-Pak or something similar.
Old 6th July 2006, 08:46 PM   #8
I know, and the L version will be sufficient, no doubt. The load current will be lower than the required minimum for the regulator, so I will have to add resistors. The question is which version will perform best at such small loads. I haven't found any previous discussion on this topic, and it seems the L version is seldomly used, at least when performance is discussed. But that might be because most applications require more current or more power dissipation?
One thing that might matter is that the T version has a thermally better package, but in this case the load current will be almost constant, so there won't likely be any changes in Tj anyway.
Maybe there will anyway be more differences between different brands than between the L and T models?
Old 6th July 2006, 09:27 PM   #9
poobah is offline poobah  United States
poobah's Avatar
I would guess the basic control circuitry is the same... while the large device has larger drive transistors. This might explain the difference in HF rejection... less base current required.
Check the die dimensions... there IS a significant difference.
Old 6th July 2006, 10:04 PM   #10
Makes sense Poobah. However, I just checked a few more data sheets (yes I should have done that earlier) and it seems not so simple either. The ON LM317M seems to behave exactly like their L version in ripple rejection vs. frequency. However, when checking some other brands, both LT317 and Samsung KA317 show a much better ripple behaviour than ONs 317T, altough not quite as good as the M and L models. Then 78xx series from ST performs even better than all of the above. Not sure I can use any of those, though.
Oh well, it seem these regulators are unpredictable and differ a lot between brands and models, or maybe the manufacturers just measure differently?
output standard? dead rat Analog Line Level 4 9th October 2008 06:54 PM
Standard SMT footprints sam9 Solid State 3 29th October 2006 01:38 AM
Non-standard rackmount Nixie Parts 5 13th October 2006 02:29 AM
Non-Standard Connectors Steve Eddy Parts 16 3rd October 2002 11:06 AM
Page generated in 0.11914 seconds (82.95% PHP - 17.05% MySQL) with 10 queries
