| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
IS THERE ANYWAY I CAN MEASURE INDUCTANCE IN THE PRIMARY
AND SECONDARY OF A POWER TRANSFORMER. I HAVE LIMITED EQUIPMENT - AUDIO OSC AND DIGITAL VOM. I HAVE A NUMBER OF SMALL POWER TRANSFORMERS AND WOULD LIKE TO USE ONE AS A FILTER CHOKE - PRIMARY IN SERIES WITH THE HIGH VOLTAGE SEC. THANKS IN ADVANCE FOR ANY HELP. PHH |
#2 |
Speakerholic
Hi Henry,
Please post without your caps lock on. Thank you |
#3 |
Hi henryp,
I assume you're aware of the limited current you'll be able to push through a power transformer, and the fact that inductance will alter along with core saturation. Put a 10k resistor in series with the winding and connect the string across your oscillator (I am assuming the osc Zo is insignificant). Sweep until the V across the resistor is 0.7 times the oscillator's Voutput. At that frequency, the inductive reactance equals 10k. Due to interwinding capacitance, it will be necessary to get a good reading below about a couple of kHz. If you sweep up and find the frequency of the minimum voltage across the resistor, make sure your reading was at a significantly lower frequency, otherwise use a different value of resistor. |
| How to measure inductance in the x-over. | marchel | Multi-Way | 3 | 12th December 2007 12:23 PM |
| How to measure small inductance? | lumanauw | Solid State | 21 | 13th January 2007 12:44 AM |
| Who might be able to measure inductance? | fazman | Multi-Way | 8 | 21st August 2006 01:26 PM |
| LCR meter to measure inductance | SimontY | Parts | 14 | 22nd April 2004 05:47 PM |
| How to measure inductance? | Jimmy154 | Multi-Way | 41 | 20th July 2003 04:37 AM |
| Page generated in 0.07613 seconds (71.06% PHP - 28.94% MySQL) with 10 queries |
