Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
My Transistors, original or copy?
Old 1st March 2007, 08:06 PM   #61
sbrook is offline sbrook  Canada
One of the other problems in the "fake" market is the manufacture of "onspec" devices. A company goes to a manufacturer and asks them to do a run of say 100,000 unlabelled NPN and specify the simplest factors like VCE HFE and Dissipation.
Then they go and label them themselves with comparable type part numbers. Sometimes they're OK in the end user app. other times they're a disaster.
One of the clues with the "nonumber" parts is a different printing for the date code and the label. But you can't rely on that either, because a lot of transistors are similar and are manufactured from the same basic dies and are then selected and labelled according to the tests.
It's like buying in the "interchange" market. There are subtle differences between similar numbers, like BC182, BC183 and BC184 (BC107, 108 and 109) transisitors, but you'll often find them all under a single interchange number which for many applications, they are, but with different VCE and HFE and gain bandwidth products, you could come unglued.
Old 7th March 2007, 11:01 AM   #62
halfgaar is offline halfgaar  Netherlands
halfgaar's Avatar
Is it possible that there also are fake TO92 devices? I recently got a couple of 2sa1123 transistors, to replace a couple of noisy input-stage 2sa942 ones. I got about 8 or so in total. A few were dead on arrival, a few died after installing, and the ones that do work, have widely differing Hfe values.
These are the original and the replacement:
Old 7th March 2007, 02:19 PM   #63
anatech is offline anatech  Canada
anatech's Avatar
Hi halfgaar,
The new transistor is okay for a sub, but I would have used 2SA872 instead.
With a wide gain spread and high failure rate, I would say those are either copies or factory rejects.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 7th March 2007, 02:43 PM   #64
2sa1123 is manufactured by Panasonic (Matsushita) and has the standoff blips on the leads and a factory lead offset like the 2SA942 you took out. Your 2SA1123 has neither. I'd say it is a fake since it appears that it doesn't even meet the specs.
Moreover, Panasonic has superceded the A1123 with the A1123S
Old 7th March 2007, 03:10 PM   #65
halfgaar's Avatar
What exactly are standoff blips?
Like so?:
edit: I assume the 2SA872 also has an offset middle pin?
Since when is this?
Old 7th March 2007, 03:28 PM   #66
Not quite ...
Look at your A942 ...
The outer two legs bend outwards and then down. That's actually done in the transistor production and not during assembly into a board. This appears to be standard on Matsushita (Panasonic) TO92 case transistors.
Then also as you come out of the bottom of the A942, the legs get fatter and then thinner again (blips). This is so that the transistor cannot seat all the way down on the board when inserted into a PCB (It "stands off" the PCB)
See here ... http://www.ortodoxism.ro/datasheets/...JC00011BED.pdf
Old 7th March 2007, 07:40 PM   #67
anatech's Avatar
Hi sbrook,
Lead forming occurs when components are supplied taped. Bulk transistors are typically straight with no bends. Component insertion machines need the bends done before they ram the part into the PCB. Just because the leads are not formed does not mean they are fakes.
I use offset pliers to form the leads into that shape.
The 2SA872 matches the specs of your 2SA942 more closely.
-Chris
Old 7th March 2007, 07:55 PM   #68
halfgaar's Avatar
What about the standoff blips?
Old 7th March 2007, 09:19 PM   #69
anatech's Avatar
Hi halfgaar,
That's just a crimp. Special order I suspect. It's the same thing, parts supplied on tape for automatic insertion. Bulk parts are supplied with straight leads generally.
Old 7th March 2007, 09:55 PM   #70
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I think that TO-92 devices have by far the largest fake market, although the quality sometimes is not as deceiving as with high power devices.
If some devices were faulty on arrival, you should return all them, get your money back and try another source. According to what you tell, all seem to be fakes (unless you managed to damage them in some unexpected way).
I use to feel like the small child in The Emperor's New Clothes tale
My Transistors, original or copy?Hide this!Advertise here!
NTE transistors-->> Backwards from original case layout!! What the heck! 777funk Solid State 1 10th May 2009 02:49 AM
Need DVD copy software! Kyte_08 The Lounge 7 16th February 2008 01:48 PM
how to backup original cd as the same sound quality as original cd ctrn Music 3 16th May 2006 04:21 PM
Copy of Kore-Eda pre ? sinski Chip Amps 2 4th May 2006 12:03 PM
