Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
My Transistors, original or copy?
Old 16th January 2007, 01:41 AM   #51
anatech is offline anatech  Canada
anatech's Avatar
Hi Pete,
I've seen some die covered with some kind of clear sealer before in parts I know are real. Factory original dead things.
Yeah, the encapsulent can smell pretty bad. I've opened a few in years gone by.
-Chris
Old 18th January 2007, 06:35 AM   #52
mitwrong is offline mitwrong  China
mitwrong's Avatar
Send a message via AIM to mitwrong Send a message via MSN to mitwrong Send a message via Yahoo to mitwrong
Originally posted by anatech
Hi Pete,
Those transistors look to be very good for a SymAsym.
-Chris
Can anybody tell me about what's SymAsym?????
Old 18th January 2007, 01:38 PM   #53
anatech's Avatar
Hi Mitwrong,
The symasym was a joint project by MikeB and Pavel. They both did a lot of work on this. Here are three threads:
http://www.diyaudio.com/forums/showt...27#post1020427
http://www.diyaudio.com/forums/showt...532#post683532 the original.
http://www.diyaudio.com/forums/showt...23#post1020423
And my search results (many!) are here ....
http://www.diyaudio.com/forums/searc...der=descending
It's a well known amp in this forum.
-Chris
Old 22nd January 2007, 01:34 AM   #54
mitwrong's Avatar
Anatech:
Thanks for your info on Symasym. This makes me more unstanding on it.
Thank you very much
Old 22nd January 2007, 02:48 AM   #55
anatech's Avatar
Hi Mitwrong,
I am biased.
With the help of Mike and Clem-o, I built a pair of Symasym amplifiers. At about 50 W, they are the right size for many projects. I can tell you that they sound very good. Well beyond the economical amplifier that Mike set out to design. This amp project is a credit to everyone who contributed on this forum.
-Chris
Old 28th January 2007, 10:25 AM   #56
mahirerensan is offline mahirerensan  Turkey
I have fifty pieces IR2113 .I am working doing classD amp.These copy.Many mosfets was broken down.I bought the original IR2113.The circuit worked immediately.
I could not believe in.look out!
Old 30th January 2007, 04:36 AM   #57
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
just wondering..... anybody found any fake 2SC5200/2SA1943 transistors?....... just troubleshot two amps today that have shorted output devices, and ordered new transistors. just want to make sure the new ones aren't fake. the originals had laser etched part numbers, and were so hard to read black on black), i had to rub heat sink grease into the lettering to get it to show up. just recently started working at this pro-audio shop, and want to be sure the parts supplier i have been buying from is selling real parts. never had a problem with them before, but with the prices i saw for these parts, i just want to be sure.....
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 1st February 2007, 04:36 AM   #58
as to the use of "goop" on dies..... i have seen the inside of a lot of motorola to-3 transistors, and they always have a drop of clear silicone rubber rubber on the die.
Old 5th February 2007, 03:54 AM   #59
PB2 is offline PB2  United States
PB2's Avatar
Default Sanken Pictures
Pictures I took of the Sanken parts:
I got a bit too close with the cut off disk and ground off
the plating and exposed the copper on a few of these:
http://i150.photobucket.com/albums/s...NKEN/CLOSE.jpg
http://i150.photobucket.com/albums/s...ANKEN/OPEN.jpg
http://i150.photobucket.com/albums/s...CLOSE_OPEN.jpg
These parts look good as far as I can tell.
Pete B.
Old 5th February 2007, 10:02 PM   #60
anatech's Avatar
Hi Pete,
They look real enough to me!
-Chris
My Transistors, original or copy?Hide this!Advertise here!
NTE transistors-->> Backwards from original case layout!! What the heck! 777funk Solid State 1 10th May 2009 03:49 AM
Need DVD copy software! Kyte_08 The Lounge 7 16th February 2008 02:48 PM
how to backup original cd as the same sound quality as original cd ctrn Music 3 16th May 2006 05:21 PM
Copy of Kore-Eda pre ? sinski Chip Amps 2 4th May 2006 01:03 PM
Copyright ©1999-2017 diyAudio
