Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
My Transistors, original or copy?
Old 19th July 2014, 06:52 PM   #561
davada is offline davada  Canada
Check the date codes against when production stopped.
David.
Old 18th September 2014, 07:18 PM   #562
kees52 is offline kees52  Netherlands
Is there a trustable chinese?
I need a good one for weld igbt and fast rectifier diodes.
regards
kees
Old 18th September 2014, 08:23 PM   #563
basreflex is offline basreflex  Spain
tme.eu has a nice selection, real brands, reasonably priced, and quick delivery, mostly overnight if ordered before 16.00 ams time
Old 2nd October 2014, 11:13 PM   #564
bear is offline bear
expert in tautology
bear's Avatar
To my eye alone they look like the ones I have had for a long time.
I have not popped the cover, although I have a few that burned through that I kept to show people. Suppose I could peek at the die, albeit burnt and compare if Chris Goldring is still around.
I never ever blew one from handling, etc. reasonably robust in that regard. Blasting them with a HV static discharge from ur carpet, another matter, never have that problem here.
_-_-
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 8th November 2014, 03:50 PM   #565
albertka is offline albertka
what is the equivalent of each of the transistors attached?
Old 12th November 2014, 04:35 PM   #566
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Bought some depletion mode mosfets DN2540 from seller janeh2100 on ebay and they were fakes. Just be careful.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 12th November 2014, 04:55 PM   #567
linuxguru is offline linuxguru  India
Send a message via Yahoo to linuxguru
Thanks for the info, and sorry about your deal. You may want to check out the Infineon BSP129 Depletion-mode MOSFETs as an SMD alternative - there are more sources, and it's less likely to be fake (at least, from US and European sellers).
Old 12th November 2014, 05:05 PM   #568
metallicus69 is offline metallicus69  Netherlands
Sorry about that!!! He's a fakes seller, I had similar delusion from him with 2SK389V (it was a dual NPN undercover). I think I mentioned that before.
Report to eBay if you are still below 45days from the purchase and force the scum to repay you everything. Add a video with the testing of the transistor in progress uploaded to youtube. For me it worked fine.
Cheers!
EDIT: I also mentioned that the postage back is prohibitive, and would lead these fakes on the market again, anyway!
Old 12th November 2014, 07:03 PM   #569
vgeorge's Avatar
Thanks I will check them out.
Old 12th November 2014, 07:07 PM   #570
vgeorge's Avatar
Cheers!
I bought the parts some time and did not check them when I received them. This will never happen again!
Just wanted to warn people here.
My Transistors, original or copy?Hide this!Advertise here!
NTE transistors-->> Backwards from original case layout!! What the heck! 777funk Solid State 1 10th May 2009 02:49 AM
Need DVD copy software! Kyte_08 The Lounge 7 16th February 2008 01:48 PM
how to backup original cd as the same sound quality as original cd ctrn Music 3 16th May 2006 04:21 PM
Copy of Kore-Eda pre ? sinski Chip Amps 2 4th May 2006 12:03 PM
