Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
My Transistors, original or copy?
Old 30th May 2014, 07:47 AM   #541
linuxguru is offline linuxguru  India
Send a message via Yahoo to linuxguru
Fairchild SSS6N80 MOSFETs - it looks authentic, with copper lead frame and a reasonable-sized die (the one on the left is unused, the one on the right is from the same batch but failed - probably destructively avalanched.)
Old 30th May 2014, 10:28 AM   #542
janegood is offline janegood  South Africa
Originally Posted by jcdrisc View Post
Linear Systems make the LSK389 which is a current equivalent of the Toshiba part
No need for hand wringing about counterfeits
Correct. I'm waiting for samples. However, not available in the ZIP7 package but the TO-71 package will probably fit the lay-out of my Borbely power amp.
Old 6th June 2014, 11:49 AM   #543
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Default MJ15003
Anyone know if this is a genuine Motorola MJ15003 or a fake.
Old 6th June 2014, 02:41 PM   #544
davada is offline davada  Canada
The simplest test is a breakdown test. I seem to remember the die being squared up on originals. It's been more than thirty years since I had one of those oped up. Something doesn't look right about that one.
David.
Old 6th June 2014, 02:46 PM   #545
cliffforrest is offline cliffforrest  United Kingdom
This from a quick google. RHS one is a "fake"
Believe at your own risk - but yours does look clean and professional!
Old 26th June 2014, 07:46 PM   #546
obscurus is offline obscurus
obscurus's Avatar
I bought 2SC3600E / 2SA1406E pair from Japan (Wakamatsu). It doesn't look like tradition Sanyo transitor. So:
- Any one can tell if they are fake or real.
- Guide me through some tests to identify that?
Old 27th June 2014, 12:05 AM   #547
First test is to put some acetone or lacquer thinner on a Qtip and see if you can remove the lettering. If they're fake the ink will likely come off. This test is not full prof.
Do some electrical tests.
David.
Old 27th June 2014, 02:26 AM   #548
obscurus's Avatar
Thanks!
I used Qtip with acetone with a little hard on the lettering but it still remains.
So electrical tests next. Which one do I need to test on this bjt?
Old 27th June 2014, 04:33 AM   #549
Thanks!
I would do a breakdown test. There is some disagreement as to whether this should be done with the base open or shorted to emitter. You will need some form of current limiting. A 1k resistor will do. Insert a current probe into the circuit and you can test for leakage at the same time. For an NPN connect the emitter to ground and place the 1k resistor in series with the collector. Apply a positive voltage to the 1k resistor and vary the voltage from 0 to 10V greater than the collector breakdown voltage. Verify your transistor becomes a zener diode at the voltage the data sheet specifies. If it breaks down early then you have a fake. You might see smoke from the resistor.
David.
Old 27th June 2014, 06:19 AM   #550
gman76 is offline gman76  United States
I wouldn't leave the base open, tie it to GND. Seems more dangerous to leave base floating. It's best to do this on a curve tracer which will limit the power delivered to the DUT. I guess a series resistor will do. What's the max Vce spec? Also don't you want to check the beta? A crappy transistor will likely have a low beta.
Edit: just looked up specs. 200v Vceo and Vcbo. hFE 40 min at 10mA Ic. I would say you should measure beta in the 60 to 80 range. The collector breakdown should be > 200v (which could a bit difficult to test).
My Transistors, original or copy?Hide this!Advertise here!
NTE transistors-->> Backwards from original case layout!! What the heck! 777funk Solid State 1 10th May 2009 02:49 AM
Need DVD copy software! Kyte_08 The Lounge 7 16th February 2008 01:48 PM
how to backup original cd as the same sound quality as original cd ctrn Music 3 16th May 2006 04:21 PM
Copy of Kore-Eda pre ? sinski Chip Amps 2 4th May 2006 12:03 PM
