Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
My Transistors, original or copy?
Old 3rd October 2011, 10:36 PM   #381
nkalogridis is offline nkalogridis  Greece
Default MJL4281A MJL4302A - Dont think so...
Sourced those from ebay. The one that I opened burned at the first 2 minutes on the pcb.
I am sure those are not the real think. Lesson learned the hard way. Thankfully only a resistor was burned together with the fake transistor.
Old 8th October 2011, 09:14 AM   #382
jitter is offline jitter  Netherlands
jitter's Avatar
At work I have seen thousands of the ON MJL1302/MJL3281 over the years. Without fail they have always looked like the top and bottom left transistors in your photograph right down to the font, size and position of the printing.
Normally I am careful not to judge by looks alone, but in this case I'd be fairly certain that the bottom right one is indeed a fake.
Old 8th October 2011, 02:55 PM   #383
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Default "SC5200+2SA1943" from Toshiba with Runaway of the adjusted Idle Current Value
By the repair of the damaged pure class-A integrated amplifier Luxmann (Luxmann) L550 (L 550) I note, that the shortly ordered output devices from Toshiba (about Nedis) don't work how they actually must.
The behaviour is exact in that kind, as if I had not screwed the transistors on the heatsink (respectively as if I had used thermal isolated insulating slices - but I use mica washers).
This means, the internal chip haven't contact to the die.
I guess, I have fakes resp counterfeits, although from the typeface (kind of font) nothing is striking to see.
How I can open this kind of outline (seems to be more difficult than TO-3) ?
Are there such observations were already made?
Thank you for your comments.
Old 8th October 2011, 03:02 PM   #384
here the attachement of the transistors mentioned in my previous post. Please note: this isn't my own foto, but the kind of font is the same.
Old 8th October 2011, 08:21 PM   #385
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
What do you make out of those JFakes, eh sorry, JFets?
They measure ~6mA in majority. Got just a few to check out. Legs longer than other Tosh, x mark inside the back circle unlike other Tosh having none. Unless they packaged any outside Japan, they are highly suspicious... Is anybody having any J74s looking like those, knowing more?
Old 9th October 2011, 03:52 AM   #386
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
by the horizontal scratching across the face as if the case was shaved, i would say they are fakes. the font and everything else looks corerect, but the surface finish is not original.... upon further inspection the dot in the date code is too far to the left of the date code digits. it looks like * 7A when it should look like *7A
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 23rd October 2011, 02:55 PM   #387
loek is offline loek  Netherlands
Clamp the transistor with the wires in a bench vice and with a knife and hammer split the 2 halves. With a little luck it opens nice..
Good luck, Loek
Old 23rd October 2011, 04:11 PM   #388
triode_al is offline triode_al  Netherlands
triode_al's Avatar
I had similar typeface on the 2SJ74 JFakes made by laser burning (or some other artifice) of the letters in the plastic, with rough edges in the letters. I would not trust them
I got same leg model. And I did not buy cheapo.
albert
SPU --> tube MM/RIAA;
Pass buffer -->300B SE Anza´ Za´ka; --> FE103 sigma TQWT
Old 23rd October 2011, 04:19 PM   #389
Salas's Avatar
Has no Toshiba hallmarks at all. I chucked them out.
Old 24th October 2011, 12:34 PM   #390
Good luck, Loek
Thanks - yes this is so. Size of die looks correct.
How I can check the internal thermal resistance between the die and the metal heatsink face by a device, that is yet not damaged ??
My Transistors, original or copy?Hide this!Advertise here!
NTE transistors-->> Backwards from original case layout!! What the heck! 777funk Solid State 1 10th May 2009 03:49 AM
Need DVD copy software! Kyte_08 The Lounge 7 16th February 2008 02:48 PM
how to backup original cd as the same sound quality as original cd ctrn Music 3 16th May 2006 05:21 PM
Copy of Kore-Eda pre ? sinski Chip Amps 2 4th May 2006 01:03 PM
