Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
My Transistors, original or copy?
Old 1st November 2010, 11:05 AM   #311
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
unfortunately, this smells like an "opportunity" for counterfeiters. if i were the one making the decisions, i would have a date code cutoff from one thickness to the other and leave no ambiguity for someone to exploit.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 2nd November 2010, 05:39 PM   #312
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Default 2SC3953 Sanyo
Are those the correct cockroaches?
Old 2nd November 2010, 07:41 PM   #313
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
The more shabby Japanese devices look, the bigger chance of being genuine, imo.
So these look fine to me, identical to mine.
Couple of years ago i would have thought chances of Sanyo video TO126s being faked would be relatively small.
Used legs and the correct package details, safer bet than sparkling beauties.
(but what do I know, they shafted me with dual JFETs twice now. my machismo shell may have cracked on the surface only, but my gentle breeze inner nature still feels fragile, soiled and violated)
Old 2nd November 2010, 08:13 PM   #314
Salas's Avatar
Thanks. Reassuring. I want them for VAS or cascoding heavy ma and high gm. What do you reckon, good choices?
Old 2nd November 2010, 08:21 PM   #315
Eeh, you don't think you'll have to do heavy mA in both cases ?
For lower levels there are both better and cheaper ones.
Old 2nd November 2010, 08:30 PM   #316
Salas's Avatar
60-80mA. What better for 20-40mA?
Old 3rd November 2010, 10:27 AM   #317
R.I.P.
2sc3953 is good for VAS & Pre-Driver duty.
120Vce0 is a limitation.
It has flat gain from 3mA to 90mA
It has fT~230MHz @7mA
Your Dgrade 60 to 120 hFE @50mA is a bit low but you are never going to use them at that current. Check hFE @ a more usable current for your use.
regards Andrew T.
Old 3rd November 2010, 10:31 AM   #318
Salas's Avatar
Thanks Andrew. I can use them at 40-60mA. I have loads of high Idss Jfets 10-15mA that I could group by 4 and shield in a cascode for instance. Do you think its not a good idea when hfe will degrade at about 120?
Old 3rd November 2010, 02:20 PM   #319
R.I.P.
I did not say degrade. I said Dgrade, The extra letter code shown in your pic.
Dgrade is 60 to 120hFE at test current of 50mA.
regards Andrew T.
Old 3rd November 2010, 03:55 PM   #320
wg_ski is offline wg_ski  United States
Originally Posted by Ivey View Post
In heat flow, there are many factors that one have to consider.
And one that nobody here had considered yet is R(th)C-S. Yep, case to sink.
The thinner tab will NOT be as flat and have as good a contact if mounted using the scew hole. The thicker tab will have better transfer to the sink in this case. If mounted by pressure contact over the epoxy case (where the actual die is underneath) thermal contact will be similar IF the flatness coming out of the factory is as good (it may not be since they're doing this to be cheap).
If you don't think this matters, try mounting a high power microwave transistor without the proper shims and bang you head for weeks wondering why your gain is 4 dB low.
My Transistors, original or copy?Hide this!Advertise here!
NTE transistors-->> Backwards from original case layout!! What the heck! 777funk Solid State 1 10th May 2009 02:49 AM
Need DVD copy software! Kyte_08 The Lounge 7 16th February 2008 01:48 PM
how to backup original cd as the same sound quality as original cd ctrn Music 3 16th May 2006 04:21 PM
Copy of Kore-Eda pre ? sinski Chip Amps 2 4th May 2006 12:03 PM
