Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
My Transistors, original or copy?
Old 11th September 2009, 01:50 PM   #221
pdul is offline pdul  Denmark
It would be damn nice with some kind of factory outlet for Japanese transistors so we could rule the fakes out all together
Old 18th September 2009, 01:14 AM   #222
pliedtka is offline pliedtka  Canada
pliedtka's Avatar
To Wojtek,
Wojciech, they're OK, I think - real TOSHIBA'S, mine looked just like yours. I also bought some MJE15030/31, 340,350 SC5200/SA1943, etc. The place in Toronto area is called Global Electronics Supplies Inc. and to me they sell the real stuff.
Old 4th October 2009, 04:42 PM   #223
rubli is offline rubli  Mexico
rubli's Avatar
Send a message via MSN to rubli
Default sanken fakes
Dear fellows.
I analized some sanken transistors that I bought in different places , and besides that the "suspects" ones have a low beta, I discovered something that i would like to confirm .
I have attached two photos, I marked with a red circle the zone of interest. one has a number engraved inside this small circular recess, and the other is blank.
the one with date code 78P is definitely a fake.
Could this be considered a "rule" for detecting malicious sanken's ?
any comentarie will be appreciated
regards
Alexander rubli
alex@rubli.net
Old 4th October 2009, 08:40 PM   #224
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
if it had been the TO-3P packages, i would have better data for you on the dimples in the plastic. however, the second picture shows a dimple with rounded edges, as if the case had been stripped with a wire wheel or sandpaper, so that device is suspect. the dimple in the first picture has sharp edges.
Old 5th October 2009, 09:01 PM   #225
rubli's Avatar
thanx, where could I see more info on the dimples ?
thanx
Old 5th October 2009, 09:18 PM   #226
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
If theres a "6" or "9" there could be a difference
On the fakes I have seen shown here especially the number 6 and 9 are more rounded, which they are not on originals
Also it seems the small dot holes you have marked should be sharp edged and smooth almost shiny at their bottom
And all letters/numbers are nicely rounded at all ends
Mind you, Im no expert, I just happen to have some old burned ones
Old 6th October 2009, 12:30 AM   #227
info about the mold marks (dimples) can only be compiled if you have access to a lot of known good parts over a span of about 5 or 10 years. manufacturers do NOT publish any info on mold marks. one very good reason that mold mark data isn't published would be to keep counterfeiters guessing, but i suspect the real reason it's not published is that it's too much information to keep track of. i was lucky to find a correctly laid out drawing and description of the lot/date code/ beta range ID markings for sanken devices. toshiba keeps more accurate data on their marking layouts, and publishes the data in their "Reliability Program Guide", because their company has an active program to monitor the reliability of the devices they manufacture (and discover counterfeits as a side benefit).
Old 21st December 2009, 08:09 PM   #228
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
In this case also this thread could be of interest:
bipolar (bjt) transistor families for audio power output stages
Old 22nd December 2009, 03:03 AM   #229
the company i work for has decided to hire a testing facility that specializes in counterfeit detection. there are a lot of methods the facility uses to detect counterfeits.
1. X-ray machines to look inside the device without having to break it apart, and even look at the emitter pattern of the die.
2. transistor curve tracers which can even identify what transistor used to make a fake might have been originally
3. accurate dimensional measurements including the flatness of the heat sink tab.
4 capacitance measurements (this is currently one of the methods i use)
5. mold marks and printing (also one of the methods i currently use.
6 materials testing. are the fakes made with different materials than the original?
the biggest part of solving the problem has been to identify the sources of the fakes, bypass the processes that allow these sources to provide certain components and order the devices directly from the manufacturer of the equipment. so far, so good, but there's a steep learning curve for management, because nobody in the company has ever identified this problem before, and nobody wants to admit that an 800lb gorilla is regularly getting poked in the eye.
Old 22nd December 2009, 03:17 AM   #230
glen65 is offline glen65  United States
What kind of meter are you using to do the capacitance measurements?
My Transistors, original or copy?Hide this!Advertise here!
NTE transistors-->> Backwards from original case layout!! What the heck! 777funk Solid State 1 10th May 2009 03:49 AM
Need DVD copy software! Kyte_08 The Lounge 7 16th February 2008 02:48 PM
how to backup original cd as the same sound quality as original cd ctrn Music 3 16th May 2006 05:21 PM
Copy of Kore-Eda pre ? sinski Chip Amps 2 4th May 2006 01:03 PM
Copyright ©1999-2017 diyAudio
