Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
My Transistors, original or copy?
Old 26th March 2018, 06:32 PM   #991
jitter is offline jitter  Netherlands
jitter's Avatar
Later has come now.
We have been using this opamp in a particular product for about 15 years or so, and they've always looked like this:
I know, the BB-logo looks odd, but they're always this way and they're always acquired from authorized suppliers. This is on the most recently produced batch.
But you're probably more used to seeing the BB-logo this way:
Left 2008 vintage, right 2011 vintage.
2017 vintage ICs look like the one on the right. Any other exterior, and I'd assume them fake until proven otherwise. Especially the OPA627 is prone to being counterfeited as they are pretty expensive, even when bought in large numbers.
Do you notice anything about the lot trace codes on these ICs?
Old 26th March 2018, 07:23 PM   #992
jitter's Avatar
But beware... looks alone may be deceiving as the better counterfeiters will try to match them as closely as possible.
Even through this may look similar to the OPA350 in my previous post, the rough edges make me think this might be a counterfeit too..
And the lot trace code seems a bit too similar to that of the right OPA627 to be a coincidence...
Buy from Mouser or Digikey and you'll likely get the real thing, buy off fleabay, and fakes are what you will get...
Old 27th March 2018, 05:04 AM   #993
jitter's Avatar
Originally Posted by jlithen View Post
But on a more global scale...what does Linear Systems say?
This fake junk certainly hurts their business. And they have probably purchased some rights for something if they make LSJ74 and LSK170 today... Just a though. I could ask them.
Linear Systems does indeed continue some products that the big manufacturers made obsolete, but that doesn't necessarily mean they make them to the same standards. One particular product we use is the 2N4117 low leakage FET.
Those are not without problems. The application calls for extremely low leakage, and the A-brand predecessors (Silliconix, then Vishay) never gave us any problems. The Linear Systems version are reasonably OK, but some just have too high leakage and need to be replaced.
We also had a bad batch in which the bonding wire between the metal case and the pin wasn't connected in a large percentage.
Also from a certain date, the marking is missing a numeral, and this continues to go unnoticed now for years. LS QC isn't up to snuff...
But LS is just as powerless as any other brand to do something about counterfeiting. All they can do is advize people to buy from authorized distributors. And frankly, in the end it is our responsibility too. If we all stop buying fakes, there's no market and it will collapse. Yes, Mouser and Digikey and the likes are expensive, but that is the real cost of real parts, not just markups.
Old 27th March 2018, 12:36 PM   #994
jlithen is offline jlithen  Finland
Absolutely right, nobody should buy fakes. Unfortunately there are many bad reasons to buy fakes
I sometimes have to buy parts of eBay. I always check them carefully and also claim them when needed.
Unfortunately eBay policy makes claiming fakes very hard and time consuming. (also expensive)
If component can be found from official supplier then I 100% buy from them!
I reported a few K170 listings for a few days back, I guess eBay is not gonna do crap about that.
How about we all report obviously 100% fake components on eBay. Would that motivate them to take action?
Old 7th April 2018, 01:53 PM   #995
jfetter is offline jfetter  United States
jfetter's Avatar
OPA2134 discovered.
They are working with no fails yet, but are clearly fakes.
File Type: jpeg 6F5E49FC-3C5D-457E-99A1-B4167A9BA13D.jpeg (375.7 KB, 112 views)
“A grounded grid is a happy grid”. jfetter
Old 7th April 2018, 02:30 PM   #996
anatech is offline anatech  Canada
anatech's Avatar
Then the big question is going to be, how do they perform. Get a real one and compare them.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 8th April 2018, 11:27 PM   #997
Rafael S. M. is offline Rafael S. M.  Brazil
Hello guys !
I have two TIP3055 from 2005, are those with thermal grease inside the hole. I bought more TIP3055 and TIP35C and TIP36C from several stores, but someone seems a fake, you can see a different terminal design in the exit of case, and more "sharp" at the end, the back are very bright, and others are more opaque and have a different design. Its really counterfeit or they are diferent batch/site of production
My Transistors, original or copy?Hide this!Advertise here!
NTE transistors-->> Backwards from original case layout!! What the heck! 777funk Solid State 1 10th May 2009 02:49 AM
Need DVD copy software! Kyte_08 The Lounge 7 16th February 2008 01:48 PM
how to backup original cd as the same sound quality as original cd ctrn Music 3 16th May 2006 04:21 PM
Copy of Kore-Eda pre ? sinski Chip Amps 2 4th May 2006 12:03 PM
