My Transistors, original or copy? - Page 48 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 1st December 2012, 07:04 PM   #471
Default Possible fakes from MCM?
Greetings,
I've been trying to repair a Denon DRA-600. I've gone through several sets of output transistors. I finally opened one up. This is supposedly a 2SA1106 purchased from MCM a few months ago. The die is only 1.3 mm on each side (1.74 square mm). I had the power supply current limited to about 300 mA (although there were some capacitors that could have dumped current) and this and its complement blew.
Do you think this is a fake?
Old 24th December 2012, 07:33 AM   #472
Default 2SJ74BL
I got four 2SJ74BL jfets from an eBay HK seller that are very strange.
I tested them for Idss and with great surprise at only -6Vdc (the first battery at hand, a not fully charged 9V) it was over -100mA. I tried one at -9V and it exploded. Well, I think there's no doubt they are not 2SJ74BL, I'm going to ask refund.
Old 24th December 2012, 10:55 AM   #473
and report them for attempting FRAUD !
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 24th December 2012, 11:18 AM   #474
I was the last of a long line of people that purchased that "2SJ74BL". Nobody placed a negative feedback or comment. Maybe none tested them. The seller has not replied to my remarks yet.
The exploded at -9Vdc.
Old 24th December 2012, 11:25 AM   #475
stormsonic's Avatar
m.massimo, your's J74 are fakes. Front surfaces are sanded down, they are too thin.
Originals should have glossy surface and different font type.
Old 24th December 2012, 11:42 AM   #476
Thank you for your comment. I've many original K170, but I didn't noted that difference. Good point. I've just taken some measures. K170 are 3.87mm, these fakes are 3.47mm, Toshiba states 4.1 as maximum.
There's no doubt that are fake with 100mA Idss at 6Vdc!
They sold about one hundred of them and nobody reported something strange.
I'm very surprised at it. Anybody tested them before inserting in a circuit?
Old 24th December 2012, 02:47 PM   #477
Send a message via Yahoo to linuxguru
I'm guessing that you forward-biased the G-S or G-D junction due to different pinout on the fakes. They could be re-marked j175 or similar p-channel switches, which are much cheaper.
You can try measuring Ciss across G-S with a smart SMD tester like the Mastech MS8910. All my original Toshiba 2sk170 are within / - 20 % of the published spec. The fakes tend to have very low values like 5 pF because of the smaller die area, but this is not conclusive. Some of the re-marks may be large-die devices.
Old 31st December 2012, 04:31 AM   #478
mitwrong's Avatar
Send a message via AIM to mitwrong Send a message via MSN to mitwrong Send a message via Yahoo to mitwrong
Default fake transistor from china
Nowadays, most fake transistors were manufactured in the CHINA, I've bought hundreds of different types and differ part of transistor. All fake and not meet Bvceo, and PD not as stated.
Old 31st December 2012, 02:59 PM   #479
LAJ is offline LAJ  United States
The last semiconductor I purchased from MCM was a fake.
Their management is aware of the problem.
Old 5th January 2013, 01:28 AM   #480
DaveG is offline DaveG  United States
I'm adding a few photos of obvious fakes to this thread that I ended up with awhile ago for reference.
They all looked bad right out of the bag, and after some close inspection I found several with remains of the original markings. I went through my parts and just happened to have some of the original parts on hand for comparison. These were apparently sanded down.
Sloppy work by sloppy people.
NTE transistors-->> Backwards from original case layout!! What the heck! 777funk Solid State 1 10th May 2009 02:49 AM
Need DVD copy software! Kyte_08 The Lounge 7 16th February 2008 01:48 PM
how to backup original cd as the same sound quality as original cd ctrn Music 3 16th May 2006 04:21 PM
Copy of Kore-Eda pre ? sinski Chip Amps 2 4th May 2006 12:03 PM
Copyright 1999-2017 diyAudio
