Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 30th January 2012, 10:50 AM   #431
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by zinsula View Post
Pins bent in a way which doesn't agree with the datasheet.
Tino-baby,
not one Toshiba datasheet mentions bent-leg options, but sure can be ordered, plenty examples, try K107, K246, K363, K366.
Gender bender leads likely means late production runs.
Looks like Sponge Bob has killed another thread.
Old 30th January 2012, 11:29 AM   #432
zinsula is online now zinsula  Switzerland
zinsula's Avatar
Originally Posted by jacco vermeulen View Post
Tino-baby....
Yep, sometimes I would like to get back some (in this case, some means quite a lot, unfortunately) years.
....Gender bender leads likely means late production runs.
Gender bender, ......hehe.
Thanks anyway for the information, it is very useful.
If you can't trust your ears, then CLICK HERE
Old 2nd February 2012, 05:48 PM   #433
DIYers, beware of DIY gene. I bought a pair of 805T tubes from him, one was bad. he told me to return it. return ship was $52. Sent it priority USPS he said he never received the faulty tube. He won't return emails to resolve issue.
Old 10th February 2012, 11:59 AM   #434
KatieandDad's Avatar
Default Beware fake 2SK170BL
I've just bought a batch of 2SK170BLs from www.dalbani.co.uk
They have proved to be fakes.
Old 10th February 2012, 04:24 PM   #435
Why do you think that they are fakes? Have you measured them? And?
Pa mislim sta reci!
Old 11th February 2012, 01:16 AM   #436
unclejed613's Avatar
Originally Posted by pattox View Post
Some time ago I (see post 405) I asked for opinions about whether my Toshiba sc5200s were genuine. The answer seemed to be that they were. More recently I had a bad amplifier driver transistor failure which I am trying to troubleshoot. One possible cause was bad power transistors )the sc5200's I had asked about.
I have split open 2 of them after the failure and to me the internals do look genuine. But I'm hoping someone with more expertise can give me their opinion.
big die, looks about right. what is that about 5 or 6mm? that's what it should be, and as your picture shows, no goo on top of the die.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 12th February 2012, 11:29 PM   #437
pattox is offline pattox  Australia
Thank you for the reassurance unclejed613. I also came to the conclusion that they were ok. I had split open some other similar power transistors which I knew to be genuine and when I compared them to the sc5200s they all looked much the same.
In the future, if I am in any doubt at all about the pedigree of power transistors, then I will buy one or two extra ones, split one open and look inside.
I think sacrificing one device is the most practical way to check. It is cheap insurance because a power transistor which fails and creates an output short circuit can have dreadful consequences to both the amp and speakers.
Old 13th February 2012, 01:39 PM   #438
the professional parts analysis companies use xray machines. i wish i had access to one
Old 13th February 2012, 04:01 PM   #439
pdul is offline pdul  Denmark
That might be a good idea for a new diy project
Old 13th February 2012, 04:08 PM   #440
DEFINITELY FAKES. Idss measures at 2mA for the badged 2SK170BL.
Idss should be between 6 and 12mA. Even the devices look re-badged. Look at the wiping marks on the face of the devices.
Dalbani were very quick to replace them.
Funny how the whole batch were low Idss whereas a previous order were well within spec.
NTE transistors-->> Backwards from original case layout!! What the heck! 777funk Solid State 1 10th May 2009 02:49 AM
Need DVD copy software! Kyte_08 The Lounge 7 16th February 2008 01:48 PM
how to backup original cd as the same sound quality as original cd ctrn Music 3 16th May 2006 04:21 PM
Copy of Kore-Eda pre ? sinski Chip Amps 2 4th May 2006 12:03 PM
Page generated in 0.11232 seconds (78.44% PHP - 21.56% MySQL) with 11 queries
