My Transistors, original or copy? - Page 38 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 15th June 2011, 07:58 AM   #371
Banned
You could try building a little test circuit and seeing how close to the SOA they will operate.
This will only detect small dies and not rebadged power transistors.
Measurement of Hfe may help identify fakes that pass the SOA test.
Old 15th June 2011, 08:09 AM   #372
meanman1964's Avatar
Sorry for the stupid question how do I've to build a test circuit?
What do I need?
Old 15th June 2011, 09:47 AM   #373
Banned
Default SOA Testing
First of all you need to study and understand the datasheet.
MJL4281A is rated at 350V and 15A BUT NOT SIMULTANEOUSLY
The SOA graphs show that the device can operate at 15A with a Vcc of 15V for one second. The important factor is Ptot = 230W.
So we have to pick somewhere under the SOA curve and within Ptot.
Lets use 8A and 24V, that gives us Ptot = 8x24=200W.
You will need a 24V 8A power supply. A 3 Ohm 25W resistor and a Large Heatsink.
You will need a 5W 220R potentiometer or a variable voltage source.
Basically, start with 0V on the base of the transistor and slowly increase the voltage until current starts to flow.
You should be able to increase the current within the SOA (up to 10A briefly) and the transistor should survive.
Old 15th June 2011, 11:10 AM   #374
Andy's test only works if the case (Tc) is held at 25degC.
This demands that the test signal is a short pulse (1 second) and then off until the transistor junction (Tj) is back down to 25degC.
I would do a high temperature test and de-rate the SOA for operating test Tc.
I would also choose the SOA voltage "knee" just before secondary breakdown occurs, about 50Vce.
Try 100W, i.e. 2A @ 50Vce.
Find the Tc at which the de-rating factor is 0.435 (100W/230W).
Test Tc = 150degC - [0.435 * 125Cdegrees] = 95.6degC
If Ta = 21degC the delta T = 74.65Cdegrees.
The required [Rth c-s + Rth s-a] = 74.65/100W ~ 0.75 C/W
If the device is thermally coupled (thermal compound and no insulator) to the heatsink expect Rth c-s ~ 0.2C/W This leaves Rth s-a ~ 0.55C/W
100W, 50Vce and 2A, will raise the 0.55C/W heatsink to ~ 55degrees above ambient.
The test Tc will be ~ 20degrees above the sink temperature. Test Tc will take the device to it's maximum de-rated SOA for 100W dissipation.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 28th September 2011, 05:15 PM   #375
triode_al's Avatar
Default Fake 2SJ74
I bought some 2SJ74's, thinking I would be able to match them myself, as I had 2SK170's already.
Well the 2SJ74 were very strange, in build and specs:
how they looked like:
All had scratches, one also showed an old typenumber
This is how they looked from a good source:
And these were the measurements,
top the fakes
and bottom the real ones (and matching 2SK170's)
selectie 2SK170, 2SJ74.pdf
They costed the same, so this was not an el cheapo trap. Yes, I got my money back.
take care
albert
SPU --> tube MM/RIAA; Kaneda pre; 300B SE driven by ECC35; Open Baffle PM2A, 2A9
Old 29th September 2011, 02:00 AM   #376
unclejed613's Avatar
the second pic looks like the old number was J271, but that doesn't make any sense because a J271 is a 60A MOSFET in a TO-220 case... unless it's a Siliconix number J271
a J271 (national semiconductor, siliconix or fairchild) is a general purpose p-channel jfet with a far lower transconductance. since the process for this device has been licensed to 6 manufacturers, it's likely these fets are much cheaper and plentiful than the 2SJ74 would be.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 29th September 2011, 02:24 AM   #377
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Or it could be J174,5,7???
Old 29th September 2011, 12:17 PM   #378
no, because the original numbers are clearly visible along the top of the face of the device, embedded horizontally, and the fake numbers are printed sideways vertically
Old 29th September 2011, 04:45 PM   #379
LAJ is offline LAJ  United States
My guess is the fake problem will only get WORSE. That's why you need to save ANY discarded electronics you can find!
Old 30th September 2011, 09:01 AM   #380
triode_al's Avatar
You are right. I looked at the device again today, and indeed it reads J271 (but the J is hard to read because of part of the new 'imprint' was lasered across it).
J271 is a P-Channel Switch designed for low level analog switching sample and hold circuits and chopper stabilized amplifiers, from Fairchild. Indeed, Idss between 6 and 50. Not a hifi device! Not for audio at all.
Albert
NTE transistors-->> Backwards from original case layout!! What the heck! 777funk Solid State 1 10th May 2009 03:49 AM
Need DVD copy software! Kyte_08 The Lounge 7 16th February 2008 02:48 PM
how to backup original cd as the same sound quality as original cd ctrn Music 3 16th May 2006 05:21 PM
Copy of Kore-Eda pre ? sinski Chip Amps 2 4th May 2006 01:03 PM
Copyright 1999-2017 diyAudio
