| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#351 |
diyAudio Chief Moderator
#352 |
Are you kidding.
Even today, i'd bang Darryl Hannah, Halle Berry (cat woman), Rebecca Romijn (x-men) and Milla Jovovich (5th element), provided they wear the outfits. H, i'd even do the blue diva from 5th element, for free. Without the dress, no f. way. ![]() (Mr Hauer should wish he'd be a clone, i gathered he's jacking himself up at age 67 to make some Hollywood bucks again)
Looks like Sponge Bob has killed another thread. Last edited by jacco vermeulen; 22nd May 2011 at 05:47 PM. |
#353 |
fake MOSFETS?, yes there are some out there.... just saw another post recently where somebody had a plastic TO-220 MOSFET that had been shaved and reprinted. he bought his fake MOSFETs from a vendor in hongkong (no big surprise there...)
when in doubt, a capacitance meter is your best friend. junction capacitances are usually published in the data sheet. with MOSFETs, the G-S and G-D capacitances are usually published (not sure if i've ever seen Cds published, but i could be wrong about that). same goes for bipolars, except the capacitances on the data sheet are published as Ccb and Cce or sometimes as input capacitance (Ccb) and output capacitance (Cce)
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net spammer trap: http://www1284177414881.v-dc.net/ Last edited by unclejed613; 22nd May 2011 at 09:34 PM. |
#354 |
His best lines as a replica leader maybe best in his career, ''I have seen things you people wouldn't believe...all those moments will be lost in time like tears in the rain,,, time to die'' a blood tear drops on his rain drenched face and he switches off. Sci-Fi in its finest.
#355 | |
Banned
#356 | |
it's not difficult to measure at the published voltage. apply the 25V to the junction through a 1meg resistor, and put a 1uf cap in series with the cap meter probe for isolation. the amount of capacitance error the series cap will make isn't enough to worry about. just remember it will be a couple of percent low; junction capacitances are usually within +/-10 percent or so. if the reading is 15% or more off consistently (since you have a batch of devices) i'd question their authenticity. with bipolars, i've seen not only the capacitance readings be wrong by 50% or more, but the Ccb and Cce capacitance ratio be really wrong. with good devices, if it's a 3:1 ratio, i've seen it close to 1:1 on fakes. i'd have to do a bit of testing with MOSFETS to establish a baseline, so when it comes to MOSFETS, the data sheet is where to look. but the capacitances also give a clue to the relative die size. the capacitance is roughly proportional to the surface area, but it's also inversely proportional to the thickness of the gate insulator. i've seen a relatively simple curve tracer design using a binary counter and op amp to do the gate voltage stepping.... i'm really thinking of building one (actually two, one for where i work, and one for stuff i do at home). of course it would work at a single drain voltage rather than stepping the drain voltage also, but it might be worth a try.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net spammer trap: http://www1284177414881.v-dc.net/ Last edited by unclejed613; 30th May 2011 at 06:38 AM. |
#357 |
Banned
#358 |
Batch codes are often printed using a different print head than the company logo, since the logo artwork stays the same from run to run. So the registration even on a real device may not be perfect, depending on whether they use a single or two head printer, or a movable batch number wheel windowed into the logo plate.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#359 |
Banned
As the label is recessed, I find it difficult to believe that these have had their part numbers ground off to make way for re-badging.
I could really do with a circuit to put them to test and compare them against their SOAR. |
#360 |
Magneto the Gravity Man
.....it's just as easy to post pictures using the attachment facility provided by the forum ......
...... Photobucket images disappear after a time, attachments don't !! ..... .
If it ain't broke, break it !! Then fix it again. It's called DIY ! Last edited by poynton; 30th May 2011 at 04:57 PM. |
| NTE transistors-->> Backwards from original case layout!! What the heck! | 777funk | Solid State | 1 | 10th May 2009 02:49 AM |
| Need DVD copy software! | Kyte_08 | The Lounge | 7 | 16th February 2008 01:48 PM |
| how to backup original cd as the same sound quality as original cd | ctrn | Music | 3 | 16th May 2006 04:21 PM |
| Copy of Kore-Eda pre ? | sinski | Chip Amps | 2 | 4th May 2006 12:03 PM |
| Page generated in 0.11883 seconds (85.63% PHP - 14.37% MySQL) with 11 queries |
