| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have seen this kind of heatsink a few days ago. The base is about 300mm in length. What will be your comment on this? The fins are just like enlarge fins of a car raditor. They are no more thicker than 0.7mm and very densely populated. Does the wavy fins work better than the straight ones or just a gimmick?
#2 |
Did it Himself
Should work very well. Surface area and material heat conductivity are the key factors.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
the fins do seem a little thin, particularly at the root. The root thickness works well when it is about 10% of the fin height. The fin can be tapered in profile or parallel sided. What is the gap between the fins? Less than 5mm or 6mm indicates a fan blown sink. What is the back plate thickness? a good heat transfer is achieved when thickness to conduction radius ratio is about 1:10. i.e. 5mm thick works out to about 50mm radius.
regards Andrew T. |
#4 |
It could just be due to a different method of fabricating the heat sink. I've seen heatsinks that looked like the fins had been "shaved" away from the base chunk of aluminum. Maybe with extruded heat sinks it isn't possible to make fins as thin.
#5 |
This type of fin profile tries to exploit maximum radiating surface area, with less material. I have a dozen similar heatsinks myself.
A small, lowspeed fan, should serve to improve performance.
It's not whether you win or lose, it's how you lay the blame. |
| Attack of the mutant reflow toaster | peufeu | Parts | 18 | 18th September 2009 07:42 AM |
| How good are Mutant subs | goldyrathore | Subwoofers | 2 | 17th December 2008 01:10 PM |
| What To Do With Heatsink.... | alecwek | Chip Amps | 2 | 28th July 2004 06:16 PM |
| Gryphon Simphony stand mutant | marijan | Everything Else | 10 | 11th February 2003 02:33 PM |
| Page generated in 0.08650 seconds (71.31% PHP - 28.69% MySQL) with 11 queries |
