Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd July 2006, 08:44 PM   #1
Did it Himself
richie00boy's Avatar
Default Balanced to Unbalanced Leads
Hoping Al is around...
There's three ways these leads can be done:
1) Stereo jack/XLR to phono plug, cold shorted to ground at jack/XLR end
2) Stereo jack/XLR to phono plug, cold shorted to ground at phono end
3) Stereo jack/XLR to phono plug, cold left unconnected at phono end
When you buy ready-made leads, which is generally the standard type out of the above?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 4th July 2006, 02:34 PM   #2
have you seen the RANE site for other combinations and switched ground lifts for experimenting (not mains ground lift).
Jensen also show a psuedo balanced output that costs very little to add and gains in some noise rejection.
Maybe that's not what you have.
Are you converting true balanced output to unbalanced input? Again Jensen's site shows some options that preserve the noise rejection.
D. Self has a good paper on balanced connections with unbalanced/pseudo ins/outs.
As for what is available retail, who knows?
regards Andrew T.
Old 4th July 2006, 02:46 PM   #3
Did it Himself
Thanks Andrew, but I have studied in depth several times every single one of those items you mention.
Just awaiting 'real world' info from people as per my original specific request.
Old 4th July 2006, 11:33 PM   #4
moamps is offline moamps  Croatia
There is a one more way (no. 4 ):
XLR+ to phono hot
XLR- to phono gnd
XLR GND n.c.
I don't know which way would be industrial standard, if any. The optimal choice of the wiring depends of the source output type (transformer output, electronicaly balanced etc.) and the design in question. I thus use types 2,3 and 4 in my wiring projects.
Milan
Old 5th July 2006, 12:24 AM   #5
pinkmouse's Avatar
Default Re: Balanced to Unbalanced Leads
In my experience, 2) is most common, but most techs carry a soldering iron just in case something needs to be "adapted" on site. However, it's always a good thing to mark up altered leads with a bit of tape, so the lads and lassies back in the yard can put it back to standard before it goes out on the next job.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 5th July 2006, 06:52 AM   #6
sangram is offline sangram  India
There's really no standard unfortunately, when it comes to this.
I've seen type 2 most often though, and 3 sometimes, but never type 1.
When doing my own connectors for this kind of application I always use type 2, however after reading through some of those papers I think that is wrong and the shield should be left unconnected, the signal coming off hot and cold, and find a way to plug the shield to the chassis ground (not signal ground as will be the case for all the above). Therefore not use a phono at all.
Old 5th July 2006, 08:19 AM   #7
Did it Himself
Good good, I was hoping type 2 would be most common. That means I can use the balanced output circuit I wanted to use and I will get ground loop rejection even with unbalanced inputs.
Thanks Al and Sangram.
Old 5th July 2006, 10:05 PM   #8
Ahem...I don't think you can get ground loop rejection if pin1 of the XLR (ground) is connected to the groundpin of the RCA connector. But, you may get ground loop rejection using wiring no.4 in my previous post.
Milan
Old 5th July 2006, 10:59 PM   #9
forr is offline forr  France
forr's Avatar
A circuit idea published in Electronics World, may 2006, by Marcel van de Gevel, is : "Electronic Audio Balun". It deals with the conversion of balanced to unbabalanced (and vice versa) audio signals and uses a common-mode loop. There are no CI's, only discrete bipolars.
Old 6th July 2006, 08:12 AM   #10
Did it Himself
Milan
Self says otherwise.
From Doug Self website
When an unbalanced output is being driven, the quasi- floating output can be wired to work as a ground-cancelling connection, with rejection of ground noise no less effective than the true balanced mode. This requires the cold output to be grounded at the remote (input) end of the cable.
Which makes sense to me.
I have not seen that. EW seemed to go quite downhill in recent years so I have not looked at it much. I'll try and get a copy of that one, thanks.
D1 I/V, balanced dac, unbalanced output 00940 Pass Labs 2 30th April 2005 01:12 AM
Unbalanced to Balanced mcash257 Parts 3 14th October 2004 01:03 AM
unbalanced/balanced/unbalanced conversion using transformers vladimir Solid State 10 27th February 2003 07:54 PM
unbalanced or balanced theturtle Everything Else 4 5th January 2003 05:52 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 07:18 AM
Page generated in 0.11950 seconds (79.59% PHP - 20.41% MySQL) with 11 queries
